How Do You Apply the Parallel Axis Theorem to Two Spheres Connected by a Rod?
The discussion revolves around applying the Parallel Axis Theorem to a system consisting of two spheres connected by a rigid rod. The problem involves determining the moment of inertia of the system when an axis is perpendicular to the rod and passes through the center of mass.
  • The original poster attempts to apply the Parallel Axis Theorem but expresses confusion about how the presence of the spheres affects the moment of inertia calculation. They provide an initial setup using the formula for a rod and question how to incorporate the spheres into their calculations.
Some participants have provided clarifications regarding the application of the Parallel Axis Theorem, specifically noting the distance D in the context of the problem. There is an ongoing exploration of the assumptions made about the mass distribution of the spheres and the role of the rod.
Participants note that the rod is massless and serves only to maintain the fixed distance between the two spheres. The problem does not specify the radii of the spheres, leading to the assumption that the mass is concentrated at their centers.
Zem
Inertia - Parallel Axis Theorem
Two spheres with masses M and m are connected by a rigid rod of length L and negligible mass as in Figure 10.22 (M is on the left end and m is on the right end). For an axis perpendicular to the rod, show that the system has the minimum moment of intertia when the axis passes through the center of mass. (The center of mass is halfway between the center and the left end. And x is the distance from the left end to the center of mass.) Show that this moment of intertia is I = uL^2, where u = mM/(m + M).
If you have Physics for Scientists and Engineers, by Serway, this is #22 on p. 324.
I'm having trouble with the parallel axis theorem. The rod alone has
I = 1/3ML^2 with the axis passing through its end. I'm not sure how the spheres change the formula for intertia. So I have tried to set it up as I would for a rod with no spheres, and the axis passing through the end. And using the parallel axis theorem, I've come up with this..
I_tot = 1/3ML^2 + M(L-x)^2
= 1/3ML^2 + M(L^2 - 2Lx + x^2)
From here, I'm lost. I have no idea how that could lead to I = mML^2/(m + M), as the book is suggesting in the problem. Thanks in advance for any help!
~Zem
you must remeber that the parallel-axis theroem states that I = Icm + MD^2
Mike,
D = (L - x) in this problem.
~Zem
This problem is not about the moment of inertia of a rod. The massless rod is doing nothing more than holding the two spheres at a fixed separation L. Since the sphere radii are not given, you must assume all of the mass is to be considered located at the centers of the spheres.
  • · Replies 28 ·
18K
