Fluids Homework Help: Pascal's Barrel Burst Problem
  • Thread starter Thread starter ouma serumula
    Fluids Homework
The discussion revolves around a problem related to fluid mechanics, specifically focusing on Pascal's principle and the behavior of fluids under pressure. The original poster describes a scenario involving a vertical tube placed in a wine barrel filled with water, leading to a burst due to pressure exerted by the fluid.
  • Participants discuss calculating the mass of fluid in the tube by determining the area of the tube's cross-section and using the height of the water column. There are also considerations about how to calculate the force exerted by the water on the lid of the barrel, referencing the relationship between force, area, and pressure.
Some participants have provided guidance on calculating mass and force, suggesting methods to find the necessary values. There is an exploration of the hydraulic principle and its application to the problem, but no consensus has been reached on the final calculations or interpretations.
Participants are working within the constraints of a homework assignment, which may limit the depth of exploration and the types of solutions discussed. There is an emphasis on understanding the principles rather than arriving at a definitive answer.
ouma serumula
help
in working out his principal,pascal showed dramatically how force can be multiplied with fluid pressure.he placed a long thin tube of 0.30cm radious vertically into a 20cm radious wine barrel.He found that when the barrel was filled with water and the tube filled to a height of 12m.the barrel burst.calculate the mass of fluid in the tube and the net force exerted by the water in the barrel on the lid just before ruptured.
PLZ EXPLAINE IN DETAILS
For the mass, first you need to calculate the area of a circle with 0.3 cm radius, then multiply it with 12m = 1200cm to get the volume in cm3. Then multiply volume with the density of water, which is 1g/cm3 (see this link). So mass (in grams) = volume (in cm3) for water.
Now force is mass times gravitational acceleration: [itex]F = M\times g = M\times 9.81 m/s^2[/itex].
In your case mass = volume. Suppose the volume of the water in the tube is V cm3 (V is the volume that you are supposed to calculate in the first step above, you should put in the number you calculated for volume). Then its mass is V grams. So the force exerted at the bottom of the tube is f = (V grams) times (9.81 m/s2) or approximately 10V g m/s2.
Show the force on the lid as F. You need to calculate the area of a circle with a 20cm radius. Let's say this area is A. Also say that the area of the circle with the 0.3cm radius is a. Hydraulic principle* says that F/f = A/a, or F = f A/a. Since you have calculated f and also calculated A and a, you can calculate F.
* "A force acting on a small area can create a much larger force by acting on a larger area by virtue of hydrostatic pressure," as explained under Hydraulic machinery in Wikipedia, the free encyclopedia.
Check out http://hyperphysics.phy-astr.gsu.edu/hbase/pasc.html
The force on the bottle cap is similar to the force exerted by water in the tube in your example. The force acting on the bottom of the bottle is similar to the force acting on the lid in your example.
11K
