Find an expression for the acceleration
The discussion revolves around finding an expression for the acceleration of two masses connected by a pulley system, with considerations of friction and mass properties. The participants explore the dynamics involved in the system, particularly focusing on the relationships between the accelerations of the masses.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss free body diagrams (FBD) for each mass, the effects of friction, and the relationship between the accelerations of the two masses. There are attempts to derive expressions for acceleration based on different assumptions about the system.
The discussion is active, with participants questioning their assumptions about friction and the mass of the pulley. Some have provided expressions for acceleration, while others are verifying the correctness of these expressions and discussing sign conventions.
There is uncertainty regarding the frictional forces acting on the masses and whether any additional information about the system's initial conditions was provided. Participants are also considering the implications of their assumptions on the derived equations.
aliciaw0
In the figure, find an expression for the acceleration of m_1
i don't understand why
(-m_2*g)/(((-m_2)/2)-m_1) isn't right
because the a of mass#2 is (-a_1)/2 right?
So i am assuming that the pulley has no friction and its rotation does not need to be taken into account, also the pulley does has no mass and can be treated as a point particle.
Just draw a FBD for each mass separately.
The first mass has friction f with the table (i assume this, if it is not the case than f =0 ofcourse). T is the tension in he rope
[tex]m_1a_1 = T-f[/tex]
For mass 2 you get
[tex]m_2a_2=2T-m_2g[/tex]
hence [tex]m_1 = \frac{m_2(a_2+g)-2f}{2a_1}[/tex]
This is the most general form. I do not know whether extra info was given on the masses standing still or not ? If so, some variables in the above formula will vanish
marlon
oh that's right, it never did say anything about it being frictionless, maybe that's what i did wrong.
and there was no other information about the masses standing still
Show how you arrived at this answer.
That's correct. (Be careful with signs.)
x m_1: T=m_1*a_1
y m_2: T-m_2*g=m_2*a_2
2(m_1*a_1)*g=m_2*a_2
a_2= a_1/2
2 (m_1*a_1)*g=m_2*(a_1/2)
aliciaw0 said:
x m_1: T=m_1*a_1
OK.
Two problems here:
(1) The rope pulls twice on the pulley (and thus on m_2)
(2) Careful with your sign convention. If you want to use up for positive, then be consistent. (You chose a positive a_1 going to the right.)
a_2= a_1/2
If m_1 moves to the right, then m_2 moves down: this means that if you call a_1 positive, then by your sign convention for m_2, its acceleration should be negative a_2.
Regarding sign conventions, here's what I do: I always assume a_1 and a_2 to be positive numbers. I also visualize how the accelerations relate to each other. If a_1 is to the right, then a_2 is down. Then I write my equations accordingly.
Try it again.
oh ok.. so i redid it and i got
m2 y: 2T-m_2*g=m_2*a_2
since T= m_1*a_1 i subsituted that it and solved for a_1 and got
a_1= (2*m_2*g)/(4m_1+m_2) is this right?
Looks good to me.
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 29 ·
