Is Any Dynamical Variable's Infinitesimal Transformation Canonical?
The discussion focuses on verifying that the infinitesimal transformation generated by any dynamical variable \( g \) is a canonical transformation. The transformation is defined as \( q_i' = q_i + \epsilon \left( \frac{\partial g}{\partial p_i} \right) \) and \( p_i' = p_i - \epsilon \left( \frac{\partial g}{\partial q_i} \right) \). It is established that these transformations satisfy the canonical transformation criteria, specifically the Poisson bracket relations \( \{q_j', p_k'\} = \delta_{jk} \). The Kronecker delta \( \delta_{jk} \) is confirmed to be the correct interpretation in this context.
  • Understanding of Hamiltonian mechanics
  • Familiarity with Poisson brackets
  • Knowledge of infinitesimal transformations
  • Ability to interpret Kronecker delta notation
  • Study the properties of Poisson brackets in Hamiltonian systems
  • Learn about canonical transformations in classical mechanics
  • Explore the Jacobi identity for Poisson brackets
  • Investigate applications of infinitesimal transformations in dynamical systems
This discussion is beneficial for physicists, particularly those specializing in classical mechanics, as well as students and researchers working on Hamiltonian dynamics and canonical transformations.
Lotophage
Problem: Verify that the infinitesimal transformation generated by any dynamical variable g is a canonical transformation.
I've worked out that an infinitesimal canonical transformation can be represented as follows:
q_i -> q_i' = q_i + ε(∂g/∂p_i) ≡q_i + δq_i
p_i -> p_i' = p_i - ε(∂g/∂q_i) ≡p_i + δp_i
I also know that, for any Hamiltonian, a new set of coordinates is only canonical if
{q_j',q_k'} = 0 = {p_j',p_k'}
==> {q_j',p_k'} = δ_jk
where {} are Poisson brackets and the lower scores denote subscript for the following character.
So my question is: Can I use these relationships to solve the problem? If so, how do I get started? The use of indices in these relationships confuses me, and I don't know if the δ_jk is supposed to be Kronecker delta, or some infinitesimal number. My intuition says that it's the Kronecker, but the indices used in the book I'm using are not explained, and I am unsure of how to apply the criterion for a canonical transformation to the general form of an infinitesimal transformation as given above. Any hints would be greatly appreciated!
Thanks,
Chris
Ok,
so the idea here is to prove that a certain type of transformation is canonical correct? So you need to think of what defines a canonical transformation and you have this already. The g in your equations is the quantity that is conserved if the transformation is canonical and the Hamiltonian is invariant under this transformation. You are correct that the term in your last equation is the kronecker delta. So the thing to do would be to check that your new coordinates, the ones with the primes, still obey your canonical transformation rules... that is the equations that define a canonical transformation are still satisfied.
Hope this helps. If this is unclear let me know.
Cheers
To verify that the infinitesimal transformation generated by any dynamical variable g is a canonical transformation, we can use the definition of canonical transformation as given by the Hamilton equations:
{q_j,p_k} = δ_jk
Using the infinitesimal transformation given in the problem, we can rewrite the Hamilton equations as:
{q_j',p_k'} = {q_j + δq_j, p_k + δp_k} = δ_jk
Expanding the Poisson brackets, we get:
{q_j,p_k} + δp_k∂q_j/∂q_k - δq_j∂p_k/∂q_k = δ_jk
Since the first term is already equal to δ_jk, we can simplify the equation to:
δp_k∂q_j/∂q_k - δq_j∂p_k/∂q_k = 0
This shows that the infinitesimal transformation generated by g satisfies the Hamilton equations, and therefore it is a canonical transformation.
To further verify this, we can use the Jacobi identity for Poisson brackets:
{f,{g,h}} + {g,{h,f}} + {h,{f,g}} = 0
where f, g, and h are any dynamical variables.
Applying this identity to our infinitesimal transformation, we get:
{q_j,{p_k,g}} + {p_k,{g,q_j}} + {g,{q_j,p_k}} = 0
Substituting in the expressions for {q_j',p_k'} and expanding the Poisson brackets, we get:
{q_j,{p_k,g}} + {p_k,{g,q_j}} + {g,{q_j,p_k}} = δ_jk∂g/∂q_j - δ_jk∂g/∂p_k + δ_jk∂g/∂p_k = 0
Since δ_jk∂g/∂p_k = δ_jk∂g/∂q_j due to the symmetry of mixed partial derivatives, we can simplify the equation to:
2δ_jk∂g/∂p_k = 0
