R: How does a Moving-Coil Galvanometer Indicate Current Strength?
  • Thread starter Thread starter phyphysics
    Galvanometer
The discussion revolves around the operation of a moving-coil galvanometer and how it indicates current strength. Participants are exploring the mechanics behind the pointer's movement and its return to zero when current is withdrawn.
  • Participants are examining the relationship between the current, the torque on the coil, and the behavior of the pointer when the current is suddenly turned off. Questions about the role of inertia and the mechanism of the spring in returning the pointer to zero are raised.
The discussion is active, with participants providing insights into the mechanics of the galvanometer. Some have suggested that the spring's behavior is key to understanding the pointer's return to zero, while others are questioning the assumptions about inertia and the effects of current withdrawal.
There is an implicit assumption that the participants have a foundational understanding of the principles of electromagnetism and mechanics relevant to galvanometers. The discussion does not provide complete information about the damping mechanism mentioned.
phyphysics
I know that the pointer of the galvanometer makes use of the turning effect to indicate the strength of the current. Say, the pointer is moved to the position of 8mA, if the current is suddenly withdrawn, the pointer would be pointing back to zero. What's the mechanism behind this?
A coil spring. The angle is proportional to the torque on the spring, which is proportional to the current in the coil.
AM
When the current is just switched off, then there is no turning effect on both the hairsprings and the iron cylinder. By inertia, the pointer must still pointing at the original reading, say, 8mA, so how can the pointer be flicked back to zero when the current suddenly drops to 0 ?
But as the needle turns the spring stretches. When the current drops to 0 the spring just returns to its equlibrium position (there is probably some kind of damper to slow the return).
AM
  • · Replies 17 ·
