Thread Closed
Heat Conduction
Share Thread Thread Tools
Aug11-05, 05:29 PM   #1
Heat Conduction
A styrofoam cooler (K = .030 W/mo C) has an average surface area of 0.465 m2 and an average thickness of 2.0 cm. About how long, in seconds will it take for 4.10 kg of ice at 0oC to melt in the cooler if the outside temperature is 28.0oC?
delta Q/delta t = (k*A*deltaT)/d
delta Q = 333 J/g (Lf) *4100 g = 1365300 J
(4186 J/kg*deltaT)*4.1 kg*28 C = 480552.8 J
1365300 J + 480552.8 J = 1845852.8 J = delta Q
1845852.8/delta t = ((.030 W/m C)*(0.465 m^2)*(28 C))/.02 m
Where did I go wrong?! Thanks a lot
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Aug11-05, 06:20 PM   #2
Recognitions:
Homework Helper Homework Help
I'm a bit vague on this stuff at the moment, but I would say that you went wrong when you raised the temp of water at 0ºC to water at 28ºC. (your third line)
This doesn't happen!
The temp difference (28 - 0) is just to determine the rate at which heat is being transferred from the outside of the cooler wall to the inside.
That heat is then used to melt 4.1 kg of ice at 0ºC into water at 0ºC.
Just skip the heat you added to raise the temp of water from 0 to 28.
Aug12-05, 03:23 PM   #3
I don't understand. That's still energy being used, shouldn't it be included?
Aug12-05, 05:43 PM   #4
Recognitions:
Heat Conduction
But no water has its temp raised! That's why it shouldn't be included
Heat is transfered from the outside of the wall to the inside.
All of that heat is used to melt ice. That's all. No water is heated.
What you have is an ice-water mixture.
Ice can exist at 0ºC or below.
Water can exist at 0ºC and above.
If you have a water-ice mixture, then all of it must be at 0ºC since this is the only temp at which both ice and water can co-exist.
Since the temp of the mixture is always at 0ºC, then water can't have its temp raised. So no energy is involved in doing that.
Aug12-05, 07:19 PM   #5
You need to use the heat of fusion for water to determine how much energy is required to melt the ice. Then you find how long it takes the outside heat to permeate the container and melt the ice.
Thread Closed
Thread Tools
Similar Threads for: Heat Conduction
Thread Forum Replies
Heat Conduction Classical Physics 14
Heat Conduction Introductory Physics Homework 1
Heat conduction Classical Physics 9
heat conduction Introductory Physics Homework 1
Heat conduction Introductory Physics Homework 2
