How Does Jupiter's Gravity Affect Its Gas Composition?
The discussion revolves around the effects of Jupiter's gravity on its gas composition, particularly why gases do not solidify under such immense gravitational forces. Participants explore the nature of Jupiter's "surface," the behavior of gases and liquids under pressure, and the implications for understanding the planet's structure.
  • Some participants question why Jupiter's gravity does not convert gases into solids, noting the behavior of the atmosphere during events like the Shoemaker-Levy 9 impact.
  • Others explain that Jupiter lacks a solid surface, with a pressure/density gradient that increases inward, leading to conditions where gas and liquid states are difficult to distinguish.
  • One participant mentions that hydrogen is challenging to solidify and that Jupiter's density suggests a shallow density gradient, requiring significant depth to reach liquid-like densities.
  • Another participant describes the temperature and pressure conditions in Jupiter's atmosphere, indicating that gases become supercritical fluids rather than transitioning to liquid or solid states.
  • Some contributions reference phase diagrams and critical temperatures, suggesting that hydrogen and helium cannot solidify within gas giants due to these conditions.
  • A later reply raises the idea that if pressure was sufficient, it could lead to thermonuclear reactions instead of solidification.
  • One participant expresses confusion over popular science representations of Jupiter's structure, questioning the accuracy of claims regarding solid or liquid cores.
Participants express various viewpoints on the nature of Jupiter's atmosphere and the behavior of gases under pressure, with no consensus reached on the specifics of solid versus liquid states or the accuracy of popular science depictions.
Some claims depend on assumptions about temperature and pressure conditions, and there are unresolved questions regarding the exact depths and compositions within Jupiter.
Hurricane
Why doesn't the immense gravity of Jupiter and the others turn the gases into solids? (More than just a tiny core, that is.) Does the "gas" at the surface act like a hard solid? About 10 years ago that comet, Shoemaker-Levy 9, entered Jupiter's atmosphere, broke up, and caused explosions on the surface. If the surface was just gas wouldn't it have gone through it until it hit liquid or solid? In a nutshell, I'm trying to imagine the physical nature of the surface.
Thanks in advance
Astronomy news on Phys.org
Jupiter has no surface as such. Natrually, the gravitational force is lower the further out you go, so the pressure/density are lower. So there is a pressure/density gradient - the pressure/density get higher as you go in, eventually to the point where you can't distinguish between liquid and gas.
Thank you, Russ, this helps me understand the planetary surface. I assume SL9 exploded at the surface because the speed of decent made the gas "feel" like a solid, and/or the atmospheric pressure came into play. I still wonder why the tremendous gravity doesn't force more of the liquid/gas into still more solid. I don't question why larger obects of the universe, such as stars, become solid because of the nuclear reactions.
Hydrogen is tough to make solid, so very little is known about it. Anyway, consider that Jupiter's specific density is about 1.3 (times the density of water) while Earth's is 5.5. That implies a pretty shallow density gradient (you have to go pretty far in before it gets as dense as a liquid).
As you descend into the atmosphere of Jupiter, you'll encounter the cloudtops at right around 1 atm (coincidence). The temperature there is way cold, about 160 K. Over the next 100 km or so, the temperature inceases at about 2 K/km but the pressure is building up as well. The atmosphere is mostly H2 and He, of course. As you go deeper and the pressure increases, this gas just gets denser and denser without ever becoming a liquid because it is above its critical temperature.
I don't have the depths available to me here, but as the pressure builds, the gas becomes much denser than water and, at even deeper, becomes a metal. Once again, it isn't really a liquid, gas or solid; just a supercritical fluid. A little hard to imagine. That big hunk of hydrogen metal is where Jupiter gets its immense magnetic field.
Near the center is a little Earth-sized silicate rocky core, but the "atmosphere" around it is a very hot, super high P metallic H2/He material. Not really a solid, but much denser than a liquid. The exact depths and compositions aren't really known because we don't know much about the behavior of hydrogen at those temperatures and, especially, pressures.
If you look at a phase diagram, at high temperatures and pressures, the line between liquid and gas ends.
If the pressure/density factor was great enough, then it would have triggered thermonuclear reactions rather than becoming solid, since the Gas giants are mostly made of 'H' and 'He' and i don't believe we can reach critical densities for these gases to become solid without triggering thermonuclear reactions...
Has anybody worked out the mass density requirement four four-proton fusion ignition?
H and He can't become solid inside a gas giant because they are above their critical temperature.
travelling towards the center of the gas giants ull find the that gases are being squashed into dense liquid under tremendous pressure,,, ull also find very violent temperature fluctuations in the inner atmosphere...
Ok, I was flipping through astronomy books at the public library today and came across some illustrations that showed a cutaway model of the various layers of Jupiter (and this was true for Saturn to a degree as well).
First drawn was a very thin atmoshpere, it gave the percent of gaseous He and H, CH4 (very small) and then trace gases. It then showed the next layer to be a a massive volume of liquid He and H, the next was a core of (solid) metallic H and then last was a core of "unknown" element.
What I can make from this discussion is that the bonding in question (whether it be metal-nonmetal/nonmetal-nonmetal/homonuclear I do not know) among the two (He, H) cannot occur due to temperatures at the specific depths being excessive, and instead pressures caused by gravity along with density allow He and H to exhibit liquid and solid state characteristics.
Is this correct?
If correct, why then do these popular science books indicate that there are solid/liquid cores within Jupiter? I would think that it is layman language since they are pop scie books, but seems very very misleading. I should find the name of the books and author/editors.
  • · Replies 24 ·
  • · Replies 34 ·
20K
  • · Replies 21 ·
