| Thread Closed |
mixing problem |
Share Thread | Thread Tools |
| Aug12-05, 03:46 AM | #1 |
mixing problem
there's an example problem in my textbook, but i'm stuck on how to make the first move~
"a tank contains 1000gal of water in which 200lb of salt are dissolved. Fifty gallonw of brine, each containing (1+cost)lb of dissolbed salt, run into the tank per minute. The mixture, kept uniform by stirring, runs out the same rate. Find the amount of salt y(t) in the tank at any time t." |
| Aug12-05, 04:59 AM | #2 |
Recognitions:
HINT: [tex]\frac{dA}{dt} = r_{in} - r_{out}[/tex]
where A is the amount of salt in the tank and r is the rate of salt flow in or out of the tank. |
| Aug12-05, 05:22 PM | #3 |
rate in = 50 lbs/min * (1+cost)lb / gal
rate in = y(t) / 1000 gal dv /dt = rin - rout find the intergating factor and .... |
| Aug13-05, 02:10 AM | #4 |
mixing problem
Why's rate out = y(t)/1000 gal?
| Aug13-05, 07:02 AM | #5 |
Since mathmike got the inflow right, I suspect that was just a typo. |
| Aug14-05, 05:22 AM | #6 |
crummy.... I just noticed I have a lot of typos in my original question! sorry about that! :P
thanks! i didn't consider the different units... :P |
| Thread Closed |
| Thread Tools | |
Similar Threads for: mixing problem
| Mixing Problem...HELP! | Calculus & Beyond Homework | 4 | ||
| Mixing Problem Help. | Calculus & Beyond Homework | 2 | ||
| D.E mixing problem need help with rate out | Calculus & Beyond Homework | 2 | ||
| Diff. Eqs. Mixing Problem | Calculus & Beyond Homework | 5 | ||
| mixing (DE) problem | Introductory Physics Homework | 9 | ||
