Does the 3-body problem have stable solutions?
  • Context: Graduate
  • Thread starter Thread starter kjknohw
    Stable
The discussion centers on the stability of three-body systems with non-negligible mass under Newtonian physics. It concludes that stable configurations exist, specifically when three bodies orbit their common center of mass in an equilateral triangle, provided the condition (m[1]+m[2]+m[3])^2 - 27*(m[1]*m[3]+m[3]*m[2]+m[1]*m[2]) >= 0 is satisfied. The discussion also highlights the use of Hamilton's equations and eigenvalue problems to analyze stability, with modern home computers capable of solving these equations symbolically. The concept of the Hill sphere is introduced as a critical factor for stability in planetary orbits within such systems.
  • Newtonian physics principles
  • Understanding of Hamilton's equations
  • Familiarity with eigenvalue problems
  • Knowledge of Hill sphere calculations
  • Study Hamiltonian mechanics in depth
  • Learn about eigenvalue stability analysis in dynamical systems
  • Research the concept of the Hill sphere and its applications
  • Explore numerical methods for solving three-body problems
Mathematicians, physicists, and astronomers interested in celestial mechanics, particularly those studying the stability of multi-body systems and orbital dynamics.
kjknohw
Given 3- bodies of non-negleble mass, are there stable configurations or not.
for example,
Will a planet (with non-zero mass) orbiting 1000 au away from two stars 0.1 au apart eventually leave the system if you give it 10^9999999... years; or is the system stable for a truly infinete time?
assume: Newtonian physics with point masses. (no gravitational waves no time dialation, etc.)
Note: this is a more of a mathmatical question than physical.
If no stable system exists, is there any way to estimate the time it will take for the system to destabalize.
Astronomy news on Phys.org
Yes.
Take a look at
http://groups-beta.google.com/group/rec.arts.sf.science/msg/05738a5d682962cc
and
http://groups-beta.google.com/group/rec.arts.sf.science/msg/1fd8079db42c1137
Three bodies orbiting around their common center of mass in an equilateral triangle will be stable if
(m[1]+m[2]+m[3])^2 -27*(m[1]*m[3]+m[3]*m[2]+m[1]*m[2]) >= 0
Sources
Volume 5 of of "What's Happening in the Mathematical Sciences" by Barry Cipra.
and a personal (rather messy) computerized calculation (see the second link). Basically you start with Hamilton's equations, you linearize them, and you wind up with a 12x12 eigenvalue problem. If all of the eigenvalues have negative real parts, the (linearized) system is stable.
Home computers with the right software are good enough nowadays to solve this symbolically. (It helps a lot that the matrix is very sparse).
one way to put it is also to make 2 of the stars orbit around their comon center and then let those 2 orbig with the third star around the comon center, this solution is the one nature prefer cause the chance of 3 stars bieng created at the right spot with the right distance with the right mass are slim. if u have a planet then it will have to orbit in the hill sphere of one of the stars. The most stable one i can think of is to orbit the third and "lonly" star. its hills sphere will probebly be bigger.
hill sphere radius
r=a(m/(3M))^(1/3)
the hill sphere radius (r) for a body with mass (m) orbiting a heavier body with mass M at a distance of a is approximently to that.
9K
  • · Replies 21 ·
  • · Replies 36 ·
