Thread Closed
chemical equilibrium
Share Thread Thread Tools
Aug12-05, 11:53 PM   #1
there are 2 Questions in which they seem like they should have the same answer, but apparently they dont, which is confusing.
1. 2NH3 <--> N2(g) + 3H2(g) initially, NH3 is added to empty flask. how do rates of forward and reverse reactions change as system proceeds towards eqm?
answer: forward rate decreases and reverse rate increases.
2. 2HBr (g) <--> H2(g) + Br2 (g) initially, HBr is added to empty flask. how do rate of forward reaction and [HBr] change as system proceeds to eqm?
answer: forward rate increases and reverse rate increases.
why are the answers almost opposite? is it because of [HBr] in question2? it seems like the 2 questions are the same..
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Attacking MRSA with metals from antibacterial clays
>> Femtosecond 'snapshots' reveal a dramatic bond tightening in photo-excited gold complexes
>> Beautiful 'flowers' self-assemble in a beaker
Aug13-05, 12:07 AM   #2
GCT
Recognitions:
Homework Helper Homework Help
again...what on earth? The question asks for the dynamics of forward reaction and HBR concentration....why does the answer refer to a completely different subject? Have you even posted the corresponding answer? Have you accurately posted the question?
First step in getting help with your question-post the actual question.
Aug13-05, 06:31 AM   #3
Recognitions:
Gold Membership Gold Member
Quote by answerseeker
I strongly suspect that this is not the answer to this question. Notice that the question says nothing about the rate of the reverse reaction and asks about [HBr] while the answer references the rate of the reverse reaction but not [HBr]. The answer to the first question can be explained like this: When [itex]NH_3[/itex] is first added, there is no [itex]H_2[/itex] or [itex]N_2[/itex], so there can be no reverse reaction. As the foward reaction proceeds more and more [itex]H_2[/itex] and [itex]N_2[/itex] begin appearing and reacting in the reverse reaction, increasing its rate. At the same time [itex]NH_3[/itex] is being used up, so there is less of it to react, slowing down the rate of the foward reaction.
Aug13-05, 05:42 PM   #4
Admin
These are kinetic approach to equilbrium questions.
First, use Le Chateliers Principle to find out what will happen to the equilibrium in both cases (note volume change during reactions).
Then think how rates of reaction must change in order for the system to move in the direction of new equlibrium state.
And - as it was already said - check out the second question and the second answer, as there is something fishy about them.
Best,
Borek
Chemical calculators at www.chembuddy.com
pH calculation
concentration conversion
Aug14-05, 03:00 PM   #5
The source from which i acquired the question from had a typo. I checked another source with the same question and here is the correct answer: forward reaction decrease as [HBr] decreases. i understand the answer quite clearly now.
but have another query: for reaction kinetics, when monitoring the change in a closed system, would you only look at the reactant side for the change?
also, are homogenous rxns slower than heterogenous?
Aug14-05, 04:26 PM   #6
Recognitions:
Retired Staff Staff Emeritus
Changes in the reactant side are related to changes in the product side through the stoichiometry of the reaction. For instance :
[tex]2HBr \leftrightarrow H_2 + Br_2 [/tex]
Consuming 2 moles of HBr produces a mole each of H2 and Br2. So, removing any x moles of HBr yields an increase by x/2 moles each of H2 and Br2.
[tex]\Delta [H_2] = \Delta [Br_2] = -\frac {1}{2} \Delta [HBr] [/tex]
[tex] \implies \frac {d}{dt} [H_2] = \frac {d}{dt} [Br_2] = -\frac {1}{2} \frac {d}{dt}
[HBr] [/tex]
Aug15-05, 02:13 PM   #7
consider: FeO (s) + H2 (g) <--> Fe(s) + H2O (g)
which describes the effect that a decrease in volume would have on the position of equilibrium and the [H2] in the above system?
answer: No shift, [H2] increases.
I was wondering why the [H2] increases even when there is no shift in the equilibrium.
thx
Aug15-05, 03:50 PM   #8
This is because H2 is a smaller molecule than H2O. Equilibrium can shifts with temperature, pressure, increase/decrease of chemcials, volume etc. and also the size or number of molecules.
As the volume has decreases, there is less room so more H2 is produced. However:
This is your question and I cannot fully answer it. To me, there should be a shift to the left due, to the molecule size and an increase in pressure (due to decrease in volume). I am afraid I cannot guess why there is no shift. For this, I apologise.
The Bob (2004 ©)
Aug15-05, 03:54 PM   #9
Recognitions:
To first order (ie: treating H2O and H2 as ideal gases) a reduction of the volume should have no effect on [H2], because ...
Once again, the provided answer is (partly) wrong.
Aug16-05, 01:41 AM   #10
as i see that the source's answers are not reliable, I will no longer post Q/A from that source... altho i appreciate the attempts to help me solve those defective problems.
Thread Closed
Thread Tools
Similar Threads for: chemical equilibrium
Thread Forum Replies
Chemical equilibrium Biology, Chemistry & Other Homework 12
Chemical Equilibrium Biology, Chemistry & Other Homework 1
Chemical equilibrium: Enthalpies and equilibrium contsants Biology, Chemistry & Other Homework 0
Chemical Equilibrium Introductory Physics Homework 3
Chemical equilibrium help Introductory Physics Homework 0
