Why is 'u' gone in equation 1?
  • Context: Undergrad
  • Thread starter Thread starter asdf1
The discussion revolves around the mathematical concept of reduction of order in differential equations, specifically addressing the presence of the function 'u' in a second equation derived from a first-order linear differential equation. Participants explore the implications of substituting a known solution into the equations.
  • One participant questions why 'u' appears to be absent in the first equation, suggesting confusion over the relationship between the two equations.
  • Another participant clarifies that 'u' is not present in the first equation, asserting that it is "gone" because the first equation is satisfied by the solution 'y1'.
  • A further explanation is provided regarding the process of reduction of order, detailing how 'u' is treated as a constant during differentiation, leading to its elimination in the context of the equations.
  • One participant acknowledges the misunderstanding and confirms they were referring to 'u' being absent in the second equation, not the first, and thanks others for their input.
Participants express varying interpretations of the original question, with some agreeing on the absence of 'u' in the context of the second equation while others initially misinterpret the reference to the first equation. The discussion reflects a mix of clarifications and corrections without reaching a definitive consensus on the initial phrasing of the question.
The discussion highlights potential ambiguities in the phrasing of mathematical questions and the importance of clarity when discussing concepts like reduction of order in differential equations.
asdf1
This question seems a little silly, because it looks so simple
but
There's one thing I don't understand:
If y`` +p(x)y` + q(x)y=0 ...equation 1.
and you have this equation:
u``y1 + u`(2y`1+py1) + u(y``1+py`1+qy1)=0 ...equation 2
and y1 is a solution of equation 1
then why is "u" gone in equation 1?
:P
but
:P
Because y1 satisfies the first equation and that equation is the coefficient of u in the second equation and since the first equation is set to zero when y1 is plugged into it, then the coefficient of u in the second one is zero.
but
:P
?? There never was a "u" in equation 1- I certainly would say it was "gone"!
I THINK what you are talking about is "reduction of order". Suppose y1 is a solution of equation 1 and let y= u(x)y1 (x).
Then y'= u'y1 + uy'1 , y"= u"y1 + 2u'y'1 + uy"1 .
I am, of course, using the "product rule". Notice that in the last term of both y' and y" I have only differentiated the "y1" part- its as if u were a constant.
Now plug that into the equation:
(u"y1 + 2u'y'1 + uy"1)+ p(x)(u'y1 + uy'1)+ q(x)(uy)= 0.
Combine the same derivatives of u:
u"y1+ u'(2y'1+ p(x)y1)+ u(y"1+ p(x)y'1+ q(x)y1)= 0
Now, that u (as opposed to u' and u") is "gone" from equation 2 (not equation 1- that must have been a typo) because y1 satisfies the original equation:
y"1+ p(x)y'1+ q(x)y1= 0 so
u(y"1+ p(x)y'1+ q(x)y1)= u(0)= 0.
You now have u"y1+ u'(2y'1+ p(x)y1)= 0. If you let v= u', that becomes v'y1+ v(2y'1+ p(x)y1)= 0, a simple, separable, first order equation. Solve for v(x), integrate to find u(x) and form u(x)y1 to find the second, linearly independent solution.
I think he meant gone in equation 2 or at least that's how I interpreted it.
you're both right~
sorry, i didn't write my question clearly...
i am talking about reduction of order and i meant gone in equation 2~
thank you! :)
  • · Replies 17 ·
