How does Uncertainty Principle work?
The discussion centers around the Heisenberg Uncertainty Principle (HUP), exploring its mathematical implications and interpretations. Participants examine various formulations of the principle, its relationship to physical quantities, and the nature of uncertainty in quantum mechanics.
  • Some participants assert that the expressions dE/dt >= h/2π and dS/dt >= h/2π are not true uncertainty relations, questioning the meaning of 'd' in this context.
  • Others propose that the uncertainty relation ΔxΔpx >= ħ/2 indicates intrinsic limits on the predictability of experimental results, independent of experimental error.
  • A participant suggests that using 'd' instead of 'Δ' may lead to confusion regarding the nature of the quantities involved.
  • There is a discussion about whether uncertainties can be zero, with some arguing that setting either quantity to zero violates the HUP, while others contend that it does not necessarily violate the principle.
  • Participants mention the significance of the relationship between energy and uncertainty, with references to zero-point energy and its implications in quantum mechanics.
  • Some participants clarify the distinction between h and ħ, noting that ħ = h/2π, and discuss the implications of this in the context of the uncertainty principle.
The discussion contains multiple competing views regarding the interpretation and implications of the Heisenberg Uncertainty Principle. There is no consensus on whether certain formulations are valid or on the nature of uncertainty itself.
Participants express confusion over the use of differential notation versus uncertainty notation, indicating a potential limitation in understanding the mathematical framework of the HUP. Additionally, the discussion touches on the implications of zero uncertainty and its relationship to quantum mechanics, which remains unresolved.
PrudensOptimus
WE all know that:
dE dt >= h/2pi
or
dS dt >= h/2pi
But... mathematically, what does that mean?
What's dS? That to me is change in entropy. Also the uncertainty is gretae than or equal to h/4pi
There are several sets of complementary pairs, for example:
ΔxΔpx ≥ ħ/2
ΔEΔt ≥ ħ/2
ΔωxΔωz ≥ ħ/2
etc.
What this does is place a definte limit on how accurately the results of an experiment can be predicted, note: this is not due experimental error, the uncertainity is intrinsic.
so this means ∫x dp >= h/4pi??
No, that's why using d instead of Δ may lead to confusion.
ΔxΔpx ≥ ħ/2
means that, for an elecrton (for example), uncertainty in postion along the x axis(Δx) mutplied by uncertainty in momentum along the x-axis (Δpx) is always greater than or equal to the rationalised Planck's constant (syn. with Dirac's constant and h/2pi) over 2
While this may be true, it is not the point of the HUP, in fact to use the Δ of the HUP to a differential is going against the entire meaning the HUP. The point is that neither of those quanities can be zero. To form the integral you must be have ture differentials, this means that they can be arbitrally small.
Edit, the more I think about this the less true is seems. Where is you differential on the RHS? Your relationship simply does not work.
Infact is worth noting that when a 'd' appears infront of a quantity in physics it does not mean you should neccesarily start thniking about intergration. For example in the formula for a change in entropy dS = dq/T, the dS and dq are actually non-integral and to avoid such confusion are sometimes annoted with a 'd-bar' instead of a 'd'.
It's not the HUP dx*dp>=~(h/(2*pi))? At least is how it appears in my book "Quantum theory" of David Bohm
WE all know that:
dE dt >= h/2pi
or
dS dt >= h/2pi
To understand the uncertainty relation one has to first understand what an uncertainty is. For that see
http://www.geocities.com/physics_world/qm/probability.htm
But note that dt above is not an uncertainty, in fact dE dt >= h/2pi is not a true uncertainty relation.
Pete
That is incorrect. There is no reason that an uncertainty can't be zero. If dx is zero that means that there is zero knowledge of p.
Of course dx is not an infinitesimal x - its an uncertainty in x. Big difference.
Pete
Most of the time it can be assumed that:
ΔxΔpx ≈ h/2π
ΔxΔpx ≈ h/2π
h or h bar??
Pete
Setting either of those quanities to zero violates the HUP. Isn't this a good protion of the argument for zero point energy? The fact that 0 energy is forbidden by the HUP?
Prudens Optimus: In that equation h, but remember h-bar = h/2pi, so I could of simply said "h-bar".
Setting either does not violate HUP. E.g. if the uncertainty in x is zero and the uncertainty in px is infinite then the equality is satisfied. Why do you think 0 energy is forbidden?
Pete
  • · Replies 19 ·
  • · Replies 23 ·
  • · Replies 17 ·
