Car Alternator Output: Voltage Decrease in Heavy Loads
The discussion centers on the behavior of a standard 3-phase car alternator under heavy load conditions. As the load increases, the voltage decreases due to the output impedance of the alternator and voltage regulator. The increased current drawn by the load generates a larger voltage drop across this impedance, resulting in voltage droop at the power supply terminals. A more robust power supply with lower output impedance can mitigate this effect, but voltage regulation may still fail if the regulator reaches its current limit or if the input voltage drops below the regulator's minimum threshold.
  • Understanding of 3-phase alternator operation
  • Knowledge of voltage regulation principles
  • Familiarity with electrical impedance concepts
  • Basic principles of current and voltage relationships in circuits
  • Research "3-phase alternator design and efficiency" for insights on optimizing alternator performance.
  • Study "voltage regulator current limiting" to understand how regulators protect against overloads.
  • Explore "output impedance in power supplies" to learn how it affects voltage stability.
  • Investigate "alternator upgrades for automotive applications" to identify high-output options and their benefits.
Automotive engineers, electrical technicians, and anyone involved in vehicle electrical systems who seeks to understand alternator performance under varying load conditions.
thkking
Hi.
I have what seems like an easy question, but I'm having trouble answering it myself.
As say a standard 3-phase car alternator has a heavy load placed on it, the voltage regulator would increase the current into the windings creating a greater magnetic field and thus increasing alternator current output.
But why would voltage decrease through the car as the load became heavy?
It would seem that the voltage would increase (or at least maintain it's maximum regulated level) as alternator current output increased, until the maximum regulated alternator output was reached, and at that point would still be maximum.
Thanks for any info.
It is because any voltage source has an associated output impedance. As the load becomes heavier (lower resistance), the increased current drawn by the load generates a larger voltage drop across the source impedance of the power source (in your case the alternator & voltage regulator), so the output voltage seen at the power supply terminals droops.
The beefier the power supply, the lower the output impedance. And when there is a voltage regulator in series with the power source, the regulator will have a fairly low output impedance (and hold the output voltage pretty steady), up until the point where the regulator goes into current limit (to protect itself from overheating), or until the input voltage to the regulator from the power source drops below the minimum input voltage of the regulator.
That makes total sense.
That’s what I was thinking, but it seemed too easy, lol, and my linear thinking was that as the alternator’s nominal output is going to be increased (as you said “beefier”) the impedance is increased…but then again it wouldn’t make sense to purchase a high output alternator if the impedance was increased with design. :smile:
Thank you.
  • · Replies 16 ·
