So two ships leave earth in opposite directions
  • Context: Undergrad
  • Thread starter Thread starter pigasuspig
    Earth Ships
The discussion revolves around the relativistic velocities of two spaceships traveling away from Earth in opposite directions, specifically focusing on how fast one ship would appear to be moving away from the other as observed from either ship. The inquiry includes scenarios where both ships are traveling at 0.4c and 0.8c, respectively, and seeks to understand the implications of relativistic effects on their relative speeds.
  • The original poster (OP) asks how fast one ship would appear to be moving away from the other when both are traveling at 0.4c and later at 0.8c.
  • One participant suggests using the relativistic velocity addition formula: (U+V)/sqrt(1-(v^2)/(c^2)).
  • Another participant corrects the formula to: (U+V)/(1+(UV/c^2)), explaining that U and V represent the velocities of the ships with respect to Earth.
  • A calculation is provided for the case of both ships traveling at 0.4c, yielding a relative speed of approximately 0.69c.
  • One participant notes that using two velocities less than the speed of light will always result in a relative speed less than the speed of light, even for values approaching c.
  • It is pointed out that if one of the velocities is c, the result will always be c, regardless of the other velocity.
Participants generally agree on the use of the relativistic velocity addition formula and its implications, but there is no consensus on the interpretation of the results or the specifics of the calculations presented.
The discussion includes some assumptions about the applicability of the relativistic formulas and does not resolve the nuances of how these formulas are derived or their limitations in certain contexts.
pigasuspig
This has probably been answered before, but I couldn't find it online.
So two spaceships leave Earth in opposite directions. Suppose they are both traveling away from Earth at .4c.
From one of the ships, how fast would the other appear to be moving away?
And then, same question, except both ships are going .8c away from Earth. If it would be impossible for the other ship to be moving 1.6c away, how fast would it be moving away (ignoring Earth)?
Use the relativistic formulas.
(U+V)/sqr(1-(v^2)/(c^2))
unfortunately, I'm not a physics student - I'm just curious. How does the formula work?
That should be:
[tex]\frac{U+V}{1+\frac{UV}{c^2}}[/tex]
To answer the OP's question, U is the velocity of one ship with respect to Earth and V is the velocity of the other ship. The answer is the velocity of the ship with respect to each other as measured from either ship.
For this particular example this gives:
[tex]\frac{0.4c+0.4c}{1+\frac{(0.4c)(0.4c)}{c^2}}= .69c[/tex]
oops!
I was using the original equation and trying to remember what the 2 velocity one was and forgot the bottom portion.
To expand upon what Janus has said, you will notice that any time you fill in two velocities which are less than the speed of light, you will be returned a velocity less than the speed of light. Even if you use [tex]U = V = .99999c[/tex].
Also note that if you fill in c for one of the velocities, you will be returned c, no matter what the other velocity is:
[tex]\frac{U + c}{1 + \frac{Uc}{c^2}} = \frac{U + c}{\frac{c}{c} + \frac{U}{c}} = \frac{U + c}{\frac{c + U}{c}} = c(\frac{U + c}{c + U}) = c[/tex]
So everyone always measures the speed of light to be c.
Thank you all for your help - it's great to know such sites as these exist.
  • · Replies 115 ·
10K
  • · Replies 25 ·
  • · Replies 98 ·
10K
  • · Replies 24 ·
  • · Replies 31 ·
  • · Replies 22 ·
