Projectile motion via a spring (well, actually, rubber bands )
The discussion revolves around a physics assignment involving projectile motion, specifically launching a tennis ball using rubber bands from a height. The original poster has gathered data from multiple trials, including the mass of the ball, distances traveled, and the height of the launch point, and is seeking to predict landing distance, determine the spring constant of the rubber bands, and find the initial velocity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need for formulas connecting the variables of the problem, including the strength of the rubber bands, initial velocity, and positions. There are inquiries about how to derive the spring constant and initial velocity from the available data.
Some participants have offered guidance on working backwards from the measured range and launch angle to find the initial speed. There is acknowledgment of the need for additional measurements, such as the stretch distance of the rubber bands, to determine the spring constant. The conversation reflects a mix of confusion and attempts to clarify the necessary steps without reaching a consensus.
Participants note the lack of recorded flight times and the potential for using approximations in calculations. There is also mention of the challenge posed by the dual components of projectile motion and the need for clear formulas to navigate the problem.
caddyguy109
Okay, here's the deal. 2nd day back at college and I pretty much have forgot most everything Physics related already :rolleyes:
Had a very easy assignment today in one of my engineering classes to take two dowels and a bunch of rubber bands and build something that could launch/throw a tennis ball from atop a terrace towards a point on the ground below (goal to get as close as possible, if not a bulls-eye). So, you say, that's elementary stuff, what's the problem? Here you go:
I have:
-the mass of the ball
-the distance it traveled in 4 different trials
-the times it traveled
-the actual distance from the terrace to the target (x)
-the height of the terrace (y)
I need to write and use equations to:
1) predict where the ball will land (assuming we hadn't actually launched it)
2) determine the effective spring constant for the system (in this case, two strings of rubber bands)
3) in addition to, I guess, finding the initial velocity using what info. I have
So, while this is, in essence, so easy it hurts, I'm brain dead right now and just need to know how to get/do #1,2,3 based on what I already have (ball mass,travel/height distances, and times).
Thanks!
Anyone? All I need is k, v, and distance... :smile: ...except I'm too stupid to remember how to get those 3 things... :confused:
Anyone...please?
Do you know any formulas connecting the things you are given: strength of the rubber bands, initial velocity, and initial position, and final position?
Well, here's what I do have:
Equations on our sheet:
v=v0+at
y=y0+v0*sin(theta)*t+(1/2)at^2 where a is gravity
x=x0+v0*cos(theta)*t+(1/2)at^2 "a" is zero, ignoring deceleration due to wind resistance
KE=(1/2)mv^2
PE=mgh
f=ma
(1/2)Kx^2=(1/2)mv^2
Don't know the strength of the rubber bands, which I guess is why we're supposed to find the "spring constant" or k of our rubber bands. Similarly, that's also why I need to find the initial velocity, from what I do have. Initial position is, I guess, the launching point at 10'3" height off the ground (y-value) and horizontally at 50'3" from the target (though it really only traveled horizontally 2'11", 7'6", 16'1", and 38'2" from the launching point when we shot it).
Using those numbers, plus the ball mass of 5oz./0.14kg, and a launch angle of 30deg., the main lines in my instructions with that all says "Develop the equations of motion describing the tennis ball's flight and use them to predict where the tennis ball will land. Determine the effective spring constant for your system."
Do you HAVE these rubber bands? any known weights?
It would be a lot easier to measure their elasticity
BEFORE tying fastening them into a device!
That's true, but it was never meant to be that complicated. Apparently we're just supposed to take the distance and mass results we have and, coupled with the given equations, answer those two main questions (i.e., the "spring" constant of the system and the expected shoot distance).
you mean wasn't expected to be that straightforward!
Working backwards from measured range and launch angle
can get you the initial speed pretty easily (recall, max at 45).
But to get the rubber band's "k" , you need measured stretch distance,
or its mechanical advantage and time duration in launcher, or...
Oh, forgot, I do have that--stretched it 2ft back from 0, to shoot.
And the flight times weren't recorded, but I can make them up fairly accurately if need be.
So what formulas should I use? I always get confused with projectiles, because of there being both x and y components of velocity, etc., so what to use?
If someone could just guide me a little with the right formulas, I could probably take it from there...until then, I'll keep trying it incorrectly :rolleyes:
Here's how far my stupidness has gotten me...
http://img388.imageshack.us/img388/3677/egrproblem5dq.jpg
...ponder and point out what is wrong.
You're going to FUDGE data??
No, not exactly, I said that wrong. I meant I specifically hadn't recorded them down, but someone else did, I just have to get them from them. Until then, I'm just going to plug in "good guesses" if you catch my drift, and finalize it all when I get the real ones.
Anything look blatantly wrong on my sheet so far? Can't believe I forgot so much so quickly...
  • · Replies 39 ·
  • · Replies 16 ·
  • · Replies 35 ·
