Calculating Mean Square Radius with QM Integration: Step-by-Step Guide
  • Thread starter Thread starter sniffer
    Integration Qm
The calculation of the mean square radius using quantum mechanical integration is achieved through the expression ρ² = (∫ |ψ|² r² dr) / (∫ |ψ|² dr), where ψ = Σₖ aₖ exp(ikr). The numerator is simplified by substituting the wavefunction and applying the product rule for integration, leading to ρ² = (Σₖ aₖ* aₖ (∫ r² dr)) / (Σₖ aₖ* aₖ (∫ dr)). The final result confirms that the mean square radius equals 1, assuming the wavefunction is normalized.
  • Understanding of quantum mechanics and wavefunctions
  • Familiarity with integration techniques, particularly integration by parts
  • Knowledge of complex conjugates and their application in quantum mechanics
  • Basic proficiency in mathematical notation and delta functions
  • Study the properties of wavefunctions in quantum mechanics
  • Learn about the application of integration by parts in quantum calculations
  • Explore the significance of normalization in quantum states
  • Investigate the use of delta functions in quantum mechanics
Students and professionals in quantum mechanics, physicists working on wavefunction analysis, and researchers involved in computational quantum chemistry.
sniffer
if i want to calculate mean square radius by using:
[tex] \rho^2=\frac{\int \mid\psi\mid^2 r^2 dr}{\int |\psi|^2 dr}[/tex]
with [itex]\psi=\sum_{k} a_k exp(ikr)[/itex].
How do I solve the numerator part?
Have you considered integrating by parts?
Carl
To solve the numerator part, we first need to substitute the given wavefunction \psi into the expression for mean square radius. This gives us:
\rho^2=\frac{\int \mid\sum_{k} a_k exp(ikr)\mid^2 r^2 dr}{\int |\sum_{k} a_k exp(ikr)|^2 dr}
Next, we need to expand the square of the wavefunction using the complex conjugate. This gives us:
\rho^2=\frac{\int \sum_{k} a_k^* exp(-ikr) \sum_{k'} a_{k'} exp(ik'r) r^2 dr}{\int \sum_{k} a_k^* exp(-ikr) \sum_{k'} a_{k'} exp(ik'r) dr}
We can then simplify the numerator by using the product rule for integration and separating the terms with different values of k and k'. This gives us:
\rho^2=\frac{\sum_{k} \sum_{k'} a_k^* a_{k'} \int exp(-ikr) exp(ik'r) r^2 dr}{\sum_{k} \sum_{k'} a_k^* a_{k'} \int exp(-ikr) exp(ik'r) dr}
Now, we can use the fact that \int exp(-ikr) exp(ik'r) dr=2\pi\delta(k-k') to simplify the expression further. This yields:
\rho^2=\frac{\sum_{k} a_k^* a_k \int r^2 dr}{\sum_{k} a_k^* a_k \int dr}
Finally, we can solve the integrals in the numerator and denominator to get:
\rho^2=\frac{\sum_{k} a_k^* a_k \frac{r^3}{3}\Bigg|_0^\infty}{\sum_{k} a_k^* a_k r\Bigg|_0^\infty}
Since the wavefunction is expected to be normalized, i.e. \int |\psi|^2 dr=1, we can simplify the expression further to get:
\rho^2=\frac{\sum_{k} a_k^* a_k}{\sum_{k} a_k^* a_k}=1
Therefore, the mean square radius for the given wave
