Calculating Stopping Distances: Braking vs. Accelerating at an Intersection
  • Thread starter Thread starter thschica
The discussion revolves around calculating stopping distances for a car approaching an intersection with a yellow traffic light. The scenario involves determining whether the driver should stop or accelerate based on given speeds, distances, and acceleration values.
  • Mixed
  • Participants explore the implications of the car's maximum deceleration and acceleration, questioning how to calculate the distance traveled under both scenarios. There is a focus on using kinematic equations to find the distance traveled during acceleration.
Participants have engaged in calculations and shared their reasoning, with some confirming the use of specific equations for distance under constant acceleration. There is an ongoing exploration of the correct values and methods, with no explicit consensus reached yet.
Participants are working under the constraints of the problem, including ignoring the length of the car and reaction time. The time limit for the yellow light is also a critical factor in their calculations.
thschica
A person driving her car at 57 km/h approaches an intersection just as the traffic light turns yellow. She knows that the yellow light lasts only 2.0 s before turning to red, and she is 30 m away from the near side of the intersection .Should she try to stop, or should she make a run for it? The intersection is 15 m wide. Her car's maximum deceleration is -6.6 m/s2, whereas it can accelerate from 57 km/h to 70 km/h in 3.9 s. Ignore the length of her car and her reaction time.
If she hits the brakes, how far will she travel before stopping?
19 m (I know how to do this one )
If she hits the gas instead, how far will she travel before the light turns red?
? m (How would I do this one?)
"whereas it can accelerate from 57 km/h to 70 km/h in 3.9 s."
How can you find her possible acceleration from this piece of info?
her speed changes from 57km/h to 70 km/h, which is a change of 13 km/h, in 3.9s.
13 km/h = 13/3.6 = 3.6 m/s
So, accln is 3.6/3.9 = .925 m/s²
You know the accln.
You know her initial speed.
You know the time limit during which she can travel.
Use the suvat eqn for distance traveled under constant accln.
a=.93
Initial speed =15.83
time = 2secs
is that right? I just can't seem to get the right answer.
That's right - you should have used the eqn: s = ut + ½at².
If you used that, what did you get.
Is the correct answer 33.52 ?
yep - close enough, depending on rounding errors.
a = 0.923 m/s²
u = 15.83 m/s
t = 2 s
s = ut + ½at²
s = 15.83*2 + ½*0.923*4
s = 31.66 + 1.846
s = 33.506 m
Thanks a lot for everything!
10K
  • · Replies 29 ·
  • · Replies 18 ·
