How Far Does the Bird Travel Between Two Trains?
  • Thread starter Thread starter ViewtifulBeau
    Velocity
The problem involves two trains traveling towards each other at a speed of 44.3 km/h and a bird flying back and forth between them at a speed of 177.2 km/h, starting when the trains are 132.9 km apart. The objective is to determine the total distance the bird travels during the time the trains approach each other.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the need for a method to calculate the time until the trains collide and how that relates to the bird's travel distance. Some express confusion about the relevance of the Pythagorean theorem and seek clarification on the setup of the problem.
Some participants have offered calculations regarding the time until the trains meet, while others are exploring different interpretations of the problem. There is no explicit consensus on the correct approach, and participants are questioning their assumptions and calculations.
Participants note that they have not covered certain equations in class, which may limit their ability to solve the problem effectively. There is also a light-hearted inquiry about the bird's speed, indicating a mix of seriousness and curiosity in the discussion.
ViewtifulBeau
2 trains have the speed 44.3 km/h, are headed each other on the same straight track. A bird that flies 177.2 km/h flies from the front of one train when they are 132.9 km apart and heads directly other train. On reaching the other train it flies directly back to the first train, and so forth.
what is the total distance the bird travels?
So i figure that I have to use pythagorian theorem. One of the legs is 132.9km but I don't know how to find the other leg. Thanks.
There are no triangles involved here, so Pythagoras isn't necessary.
There's a hard way and an easy way to do this problem. I'll let you think about it some more.
Crap, ok i disreguarded the "same" straight track. Ok so the are going head to head! But is there an equation to find the time when two objects are approaching each other? I don't know many equations, we haven't gone over any in class.
ok i thought i figured it out at 170.1km, but it says that is wrong. What did i do wrong?
First we want to find the time the two trains will collide. So [tex]\frac{132.9 km}{44.3 \frac{km}{h}+ 44.3\frac{km}{h}} = \frac{3}{2} [/itex] hours. So multiply the eagles speed by this. Remember distance divided by velocity gives you time according to [tex]d = rt[/tex][/tex]
I'm curious as to what kind of bird this is that flies at 177.2 km/h.
hk
  • · Replies 20 ·
9K
  • · Replies 31 ·
