Is Force the flux of pressure ?
  • Context: Undergrad
  • Thread starter Thread starter DaTario
    Flux Force Pressure
The discussion centers on the relationship between force and pressure, specifically whether force can be considered the flux of pressure. Participants explore the definitions and characteristics of pressure as a scalar or vector, and how these relate to force in various contexts, including fluid dynamics.
  • Some participants assert that force is the product of pressure and area, questioning if this product can be considered a flux.
  • Others argue that flux is a scalar quantity resulting from the product of force and area, while pressure can be either uniaxial or hydrostatic, complicating its classification as a vector.
  • A participant suggests that in a small cube, if pressure does not cancel out, it may exhibit directional characteristics, raising questions about the rigorous treatment of this concept.
  • One participant contends that directional pressure does not exist and explains that in an ideal fluid scenario, pressure acts uniformly as a scalar function, regardless of the orientation of the area.
  • Another participant emphasizes that force is exerted in all directions, which contradicts the notion of force being the flux of pressure, and highlights the need for integration to account for pressure gradients across an area.
  • A later reply introduces a thought experiment involving a straw in a cup of tea, questioning how to describe the pressures involved when the pressure inside the straw is suddenly reduced.
Participants express differing views on the nature of pressure and its relationship to force, with no consensus reached on whether force can be accurately described as the flux of pressure.
The discussion includes unresolved definitions and the implications of treating pressure as a scalar or vector, as well as the mathematical complexities involved in integrating pressure gradients.
DaTario
According to general information I can find in introductory books of physics, area is a pseudo-vector while force is a vector. Pressure appears defined as the ratio between then. Put differently, force will come as the product of pressure and area. Does this product is in the same sense of a flux ?
I would also like to ask about the vectorial character of pressure.
Consider the following statement:
The balance of a small plate depends on the pressure up-down being equal to the pressure down-up.[\b]
not exactly, flux is a scalar which is a product of force and area. The problem with pressure that it may be uniaxial (like vector) or hydrostatic (like scalar), but the force is always a vector.
so, if in a small cube, very small, if the pressure on its side does not cancel out, then some directional pressure appears. Otherwise, it is hydrostatic and is only scalar.
Is it the rigorous manner to deal with this concept ??
Best Regards,
DaTario
There's no such thing as directional pressure. Let's take an example of what I think you're talking about. Let's take an ideal fluid, rotating inside a vessel at an angular speed [tex]\omega[/tex].
Consider an element, at a distance x from the centre of the vessel. Let its width be dx, and its area be dA. Since the element is rotating about the centre, and the fluid is ideal, it is acted upon by the net force
[tex]\\ dF = \rho\omega^2 xdAdx \\[/tex]
towards the centre.
The only force that can provide the net force is the net force due to pressure. The only way pressure can provide the required force is if it increases along the radial direction. Hence,
[tex]\\ dAdP = dF[/tex]
Now, the direction comes in ONLY because of the area. The area direction can obviously be both radially inward and outward, but we needn't worry about that as long as it's in the radial direction. The point is, force is not the flux of pressure because it's exerted in ALL directions. No matter how the element is oriented, the pressure is the same scalar function of distance from the centre.
If, for instance, the element had a square shaped area A, and it were oriented so that one side of the square was closer to the centre than the other, you CANNOT take the component of area along the radial direction, and multiply it by the pressure gradient, as you probably would do if force were the flux of pressure. You would have to consider the pressure gradient at each point on the area, and then sum it up by integration! I hope this was clear...it was a little difficult for me to explain it without a diagram.
a complicated circuit of capacitor?how to solve that
Please, clearify this.
To Arun:
What is your opinion about shyboy's post :
arun_mid said:
There's no such thing as directional pressure. Let's take an example of what I think you're talking about. Let's take an ideal fluid, rotating inside a vessel at an angular speed .
towards the centre.
Let's consider what happens when a straw, which is partially inside a cup of tea, with its upper terminal open, has this same terminal closed and the internal pressure is made to fall to zero instantaneously. Consider what happens in the tea surface. How do you describe the pressure(s) there ?
Comment: obviously that, after an instant, the tea level will rise inside the straw.
  • · Replies 25 ·
  • · Replies 69 ·
  • · Replies 20 ·
12K
