Would it be possible to see into the past
  • Context: Undergrad
  • Thread starter Thread starter derek yau
The discussion revolves around the theoretical possibility of observing events from Earth's past using a telescope located 1000 light years away. Participants explore the implications of relativity, the nature of time and causality, and the practical challenges of such observations.
  • Experimental/applied
  • Some participants propose that observing Earth from 1000 light years away could allow one to see events from 1000 years in the past, but this is complicated by relativistic effects.
  • Others argue that due to the nature of spacetime, what is considered the past may actually be part of the present for the observer, depending on their frame of reference.
  • A participant emphasizes that light-like separation is crucial for seeing events, suggesting that all observers would agree on the temporal order of events if they are light-like separated.
  • Concerns are raised about the practical limitations of observing distant events, such as the need for long exposure photography to gather sufficient light and the challenges posed by Earth's rotation and weather.
  • Some participants discuss the feasibility of using large telescopes or arrays of smaller telescopes to enhance resolution and light-gathering capabilities.
  • A later reply introduces the idea of observing a distant reflective planet that could redirect photons from Earth back to the observer, but this remains a theoretical consideration.
Participants express differing views on the interpretation of seeing into the past, with no consensus on whether it is accurate to describe such observations as truly seeing the past. The discussion remains unresolved regarding the implications of relativity and the practicalities of observation.
Limitations include the dependence on definitions of past and present, the unresolved nature of relativistic effects, and the practical challenges of long-distance observation techniques.
derek yau
if you were on a planet a 1000 light years away and had a really good telescope, would you be able to see a 1000 years into Earth's past? Is it as straight forward as this or what problems might this present?
In the same frame of reference, I'm thinkin that's all you're going to see... Add some acceleration and/or travel between the two and it might get a little stranger...
Edit: well other than some gravitational considerations that might deviate the path of the light etc lol
Theoretically yes. But in relativity 1000 years ago on Earth could be considered as part of that planet's (1000 ly away) present. The following diagram might help explain.
Code:
[FONT=Courier New]
         \   future      /                          ^
           \           /                            |  time
  present      \   /    present                     |
(absolute        \/     (also known as the          +---------------------->
 elsewhere)      /\        absolute elsewhere)      |                     space
         /    past       \                          |
The point is that if a place and time cannot be causally connected to the here and now then it cannot really be called the past, and might more properly be called the present. Afterall what part of this absolute elsewhere is simultaneous with your present time is relative, that is it depends entirely upon what inertial frame you are in.
The true past and future cannot be simultaneous with your present regardless of your inertial frame and it is causally connected to your present moment.
Code:
[FONT=Courier New]
         \   future    /                                 ^
           \           /                                   |  time
         /    past     \                                 |
I basically agree with what you're saying, but I don't think the "absolute elsewhere" is usually referred to as "the present", although it's true that for any two events with a spacelike separation, there is some reference frame where the two events happen at the same time-coordinate. But there are also plenty of reference frames where they don't, and the question seems to presuppose we're using a reference frame where the event of someone receiving the light from an event on Earth happened 1000 years after the actual event. Anyway, there would be a lightlike separation between the event on Earth and the event of a distant observer seeing it, not a spacelike separation.
No it is not usually referred to as the present, therefore I gave my justification for using the term present. You could use the term absolute present as opposed to relative present if you like. A light-like separation is less than a second away from a space like separation. Our use of the word present is seldom that precise. In other words close enough.
Anyway, my point was simply that in the example given it really isn't like seeing into the past at all.
Now that said, I would like to add a comment in response to the original post that I forgot to make last time. Being able to see things with any detail at distances like 1000 light years requires long exposure photography in order to collect sufficient photons. To be able to see events on the surface of the Earth would take an awful long exposure, so that you would only be able to see the somewhat stable features of the Earth's surface like the geography and maybe a few buildings. And then there is the problem of dealing with the rotation of the Earth and the changing weather, during such long exposures. In conclusion, I think that not much of what you would call human history could be seen.
But the difference is crucial, because if there is a light-like separation, then all frames will agree on which event is in the past and which is in the future. And obviously for you to see an event at all, there must be a light-like separation between you and that event, and a moment later there is a timelike separation (you go inside that event's future light cone). So I don't think it makes sense to argue that you aren't seeing into the past when you see distant events--you are, in an absolute sense.
Thanks for the response guys, good point about the telescope part of the question too. :smile:
Well, yes of course. If you insist on being absolute about everything. But, then everything we see is in the past. Which is precise my point. It is essentially no different than anything else that we see everyday.
To resolve something the size of a building at 1000 light years will need a telescope about the size of the Earth's orbit. I would think light gathering power wouldn't be so much of a worry.
When you say light gathering power would not be a worry I assume you mean by comparison to the size of the telescope? But the solution is the same. Instead of using a large telescope you can use many small ones over the same distances or simple wait for the planet to travel through a significant portion of its orbit. I believe that we now use interference techniques for computer aided image ehancement to a higher resolution so that you don't actually need a telescope of that size.
In theory - but not in practice - we can view the past - find a distant planet with a highly reflective surface (one having an ocean) from which the photons from Earth are redirected back to Earth - all that is needed is a way of sorting out those photons that originated from the Earth's surface from all other photons that strike the same surface - and process them to recover the original image.
In essence the past is forever preserved ---until the individual photons are absorbed by striking a non-reflective surface - the information that comprises the Earth's history is stored awaiting detection - but would it really change human behavior to know the reality of the past - how many Zealots would forsake their beliefs if it were revealed that their convictions were founded upon falsehoods - not one.
  • · Replies 98 ·
10K
  • · Replies 102 ·
  • · Replies 21 ·
  • · Replies 18 ·
