Thread Closed
Electric Field charge calculation
Share Thread Thread Tools
Sep3-05, 08:31 PM   #1
Hi
This is a homework question, but Im trying to see if Ive got the format correct. Two protons are separated by 3.80 x 10-10m. Find the electric force exerted by one proton on the other
........................... |q1||q2|
So Ive got Fe =.. ke ------------
............................... r^2
Im told the proton charge is +1.6021917 x 10-19
so................... 2.5667E-38
............ke * .. -------------
...................... 1.444 E-19
then...... ke * 1.7775 E -19
then 1.5979 E-9 as the final answer?
Is there some way to write equations and allow whitespace?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Sep4-05, 01:56 AM   #2
Quote by Brad_1234
Hi
[itex] F = \frac{2.5667E-19}{1.444E-19} [/itex]
Okay I wrote this by typing this: [ itex ] F = \frac{2.5667E-19}{1.444E-19} [ /itex ] (take out the spaces in the tags with the square brackets.)
[tex] F_{total} = K_e \frac{Q_1 Q_2}{r^2} [/tex]
This was written with this:[ tex ] F_{total} = K_e \frac{Q_1 Q_2}{r^2} [ /tex ] (again take out the spaces)
Sep4-05, 02:30 PM   #3
Hey thats too cool [itex]F_{total} = K_e \frac{q_1 q_2}{r^2}[/itex]
its not working on preview, anyone know if the result is correct?
also, would 15 pounds of electrons have enough field energy to support the mass of the earth? It calculates out to be many times more, but if thats the case? batteries can still be improved to store more energy
This is my first Physics for electricity/Magnetism course
Sep4-05, 07:12 PM   #4
Without doing any equations, I'm pretty sure 15 pounds of electrons would be more than enough to support the Earth. What you mean by support the earth though, I'm not sure. The electromagnetic force is some 38 orders of magnitude (or thereabouts) stronger than gravity. You would have some problems though:
-How do you get 15 pounds of electrons without any protons
-Given that the electromagnetic force is so strong, how do you contain them, since they will want to repulse each other.
- The overall net charge on the earth (I'm assuming) is probably very close to zero, so the net force on the earth is going to be very small.
But yeah, the electromagnetic force is much, much stronger than gravity, its just that in everyday life, almost everything has the same number of positive and negative charges, so it cancels out.
Sep4-05, 08:39 PM   #5
One of our questions was 2 people standing at arms length, each has 1% excess in their body weight of electrons, would there be enough force between them to lift the mass of the earth? or something like that.
I got the result down to Newtons, starting with each person 150lbs, oops I calculated 15lbs but thats 10%? 1.5lbs of excess electrons...
And I figured the distance was 2 meters. taking the weight of electrons, dividing in 15 pounds, got some number then multiplied to get charge then applied the F_e equation with the distance as 2m and it came out to 3.23 E33 Newtons of force or 3.29 E32 kG of force and the earth weights a mere 6 E24 kG ?
Yes, how to contain the charge. dont know... maybe need particles smaller than an electron that have even stronger bonds to make a container. Arent radioactive materials extra heavy because they have too many electrons? What would it take to order the electrons back to the nucleus?
Thread Closed
Thread Tools
Similar Threads for: Electric Field charge calculation
Thread Forum Replies
electric field of a line charge and point charge Introductory Physics Homework 14
Electric field due to arc of charge Introductory Physics Homework 6
Electric field calculation using Coulomb's law for uniformly charged conducting spher Introductory Physics Homework 8
Electric charge and fields: uniform electric field Introductory Physics Homework 1
Electric field/charge Introductory Physics Homework 1
