The discussion revolves around the compatibility of CMOS and TTL logic families, specifically whether CMOS can drive TTL loads and the implications for fan-out calculations. Participants explore the specifications of both logic families, including input and output current requirements, voltage thresholds, and the need for level translation in mixed logic designs.
- Technical explanation
- Debate/contested
- Some participants propose that the fan-out formula requires using output parameters from CMOS and input parameters from TTL to determine compatibility.
- Others discuss the need to consider specific TTL and CMOS families, as different families have varying input and output specifications that affect fan-out calculations.
- A participant mentions that CMOS logic generally has lower power consumption and can drive rail-to-rail outputs, while TTL has higher input current requirements.
- There is a discussion about the significance of the "T" variants of CMOS logic, which are designed to be compatible with TTL voltage levels.
- Some participants express uncertainty about whether a "T" part can drive a non-"T" part, questioning the relationship between voltage thresholds and compatibility.
- Concerns are raised about TTL's output voltage levels potentially not being recognized by standard CMOS inputs, emphasizing the need for "T" variants in certain applications.
- Participants note that while CMOS is more common today due to lower power consumption, TTL-compatible inputs are still used for backward compatibility.
Participants express a mix of agreement and uncertainty regarding the compatibility of CMOS and TTL logic families, with no consensus reached on specific compatibility scenarios or the implications of using "T" variants.
Participants highlight the importance of checking datasheets for specific input and output characteristics, as variations exist among different logic families. The discussion reflects a range of assumptions about voltage levels and compatibility that may not be universally applicable.
This discussion may be useful for electronics engineers, students studying digital logic design, and hobbyists working with mixed logic families in circuit design.
