Writing on Paper: Graphite & Adhesion Effects
  • Thread starter Thread starter Manchot
    Paper Writing
Writing with a pencil on paper involves the friction between graphite and paper, leading to the shearing of graphite into thin flakes. These flakes adhere to the paper fibers and may penetrate into the surface pores, with finer particles achieving deeper penetration. The adhesion between graphite and paper is primarily mechanical, with some contribution from van der Waals forces, although the latter's impact is minimal. Understanding these interactions is crucial for applications in writing and drawing materials.
  • Basic understanding of material science concepts
  • Familiarity with the properties of graphite
  • Knowledge of paper composition and structure
  • Awareness of adhesion mechanisms in materials
  • Research the mechanical properties of graphite and its interaction with various substrates
  • Explore the role of van der Waals forces in material adhesion
  • Investigate different types of paper and their effects on graphite adhesion
  • Study the impact of pencil lead composition on writing performance
Material scientists, artists, educators, and anyone interested in the physics of writing instruments and their interaction with surfaces.
Manchot
I'm just curious: what happens when you write on a piece of paper with a pencil? Does the graphite actually penetrate the paper, or is it just on the surface? Also, what kind of adhesion occurs between the two materials? Thanks for your time.
Friction of drawing the graphite across the paper causes the graphite to shear in very thin flakes, which become attached to the paper fibers and perhaps embedded in the fibers or stick to the ceramic filler. The graphite particles are quire small.
They can be removed (erased) so they are at the surface with finer particles penetrating more deeply into pores in the paper surface.
The maybe some van der Waals forces at work, but the magnitude is probably small.
