What are the Electric Field Lines and Flux in Coaxial Cables?
The discussion revolves around understanding electric field lines and flux in the context of coaxial cables, specifically applying Gauss' law to analyze different charge distributions along the cables. The original poster seeks clarification on these concepts and how they relate to three specific cases of charge per unit length.
  • Participants discuss the application of Gauss' law and the use of Gaussian surfaces to analyze the electric field around coaxial cables. Questions are raised about the differences in electric field behavior in the three cases presented by the original poster.
Some participants have provided insights into the application of Gauss' law, suggesting that understanding the Gaussian surface is key to solving the problem. However, there remains a lack of consensus on how to interpret the results for each case, with ongoing questions about the implications of the different charge distributions.
Participants note that the electric field within the conductor is zero and discuss the implications of charge distribution on the inner and outer surfaces of the coaxial cable. The discussion is framed within the constraints of analyzing per unit length charges.
ussrasu
I don't really understand Gauss' law - any help with this question would be appreciated?
Coaxial cables are made of a copper wire in the center and a concentric cylindrical shell of copper outside, with insulating material in between and outside the shell. The charge per unit length of the cable are given as λ1 (positive) in the inner wire and −λ2 (negative) in the outer shell.
Sketch qualitatively the electric field lines on a plane perpendicular to the cable assuming it is very long.
Consider three cases:
(a) λ1 > λ2,
(b) λ1 = λ2 and
(c) λ1 < λ2.
Explain your diagrams using the concepts of flux and Gauss' law.
The key to understanding Gauss's law is that a Gaussian surface is a completely made up surface that you use as a tool. Since we have a wire in this problem, a good surface that perfectly encloses the wire is a cylinder(minus the bases). The cylinder's surface area would be [tex]2\pi r^2[/tex] where r is the radial distance from the wire.
Now Gauss's Law states that [tex]\int E \bullet dA=q/\epsilon_0[/tex] , where q is the charge enclosed by the imaginary surface you just created.
So if you want the electric field, but you have charge that's enclosed by any area, even one you just made up, you can use that equation to find the electric field.
It's really useful, and it makes these types of problems a breeze once you understand it.
What happens in each of the situations though? i.e in parts a) b) and c) - what is different in each of them? And how do you explain these observations in terms of Gauss' Law and Flux?
Thanks :smile:
(Charges are considered per unit length)
The E field within the conductor is zero therefore the flux originated from charge [tex]+ \lambda_1 = \frac{\lambda_1} {\epsilon_0}[/tex] is to be terminated on the inner surface of the outer cylinder and thus charge on the inner surface of outer cylinder must be - [tex]\lambda_1[/tex]
But the total charge on the outer cylinder is - [tex]\lambda_2[/tex] hence the rest of the charge remain on the outer surface and will be
- [tex]\lambda_2[/tex] + [tex]\lambda_1[/tex]
now I think you may find the correct answer for all three cases.
  • · Replies 22 ·
