How to Measure Probabilities for Observables in Quantum Mechanics?
  • Context: Graduate
  • Thread starter Thread starter Palindrom
    General Operator Self
The discussion revolves around the mathematical formulation of measuring probabilities for observables in quantum mechanics, particularly focusing on the challenges when an observable does not have eigenvalues, such as the position operator. Participants explore the implications of different mathematical frameworks, including Borel sets and spectral resolutions, in the context of quantum mechanics.
  • One participant seeks a general expression for the probability of measuring values from a Borel set for an observable without eigenvalues, noting the difficulty in associating such observables with wavefunctions.
  • Another participant suggests that if eigenvalues of an operator are contained in the Borel set, the probability can be expressed as |w(a)|² without needing an integral, while also discussing the Lebesgue integral for continuous spectra operators.
  • A question is raised about the compactness of Borel sets, with a participant expressing uncertainty about the definitions involved in measure theory.
  • One participant clarifies that the position operator does not have eigenvalues and discusses the concept of generalized eigenvectors and the spectral theorem, introducing the idea of spectral resolutions.
  • A later reply connects the spectral resolution to cumulative probability distributions, suggesting a relationship between quantum mechanics and probability theory.
  • Another participant expresses confusion about the integral mentioned and asks for clarification on the continuity of the map related to projection operators.
  • One participant offers a simplified expression for the probability in terms of projection operators, indicating that understanding the integral will be clearer with knowledge of measure theory.
  • Further discussion includes recommendations for studying related mathematical structures in quantum mechanics, such as Real Analysis and measure theory, while noting the variability in course content across institutions.
Participants express differing views on the nature of Borel sets and the implications of the spectral theorem. There is no consensus on the best approach to measure probabilities for observables without eigenvalues, and the discussion remains unresolved on several technical points.
Participants acknowledge limitations in their understanding of measure theory and the definitions of mathematical concepts, which may affect their interpretations and applications in quantum mechanics.
This discussion may be of interest to students and researchers in quantum mechanics, mathematics, and those exploring the intersection of probability theory and quantum observables.
Palindrom
I'm asking from a mathematical aspect, please be as exact as possible.
Suppose A is an observable, and B a Borel set in R (real numbers). Without further assumptions on A, I would like a general expression for the probability of measuring one of the values from B for A.
The reason for my question is that it seems I'm stuck if A hasn't got any eigenvalues (like position X), and can't be associated with a wavefunction (like position X), or put in position representation.
Please notice that the two identical brackets have opposite interpretations. :smile:
*For example, for X, the answer would be the Lesbegues integral of [tex]\[<br /> \left| \psi \right|^2 <br /> \][/tex] over B.
Really? Nobody?
Is my question not clear enough?
I'll take a crack: if some of the eigenvalues of an operaor are contained in B, then the measure (probability) will be |w(a)|**2 with no integral. For a discrete operator there should be no problem -- everything will be finite. And, as far as I can figure, the Lebesgue integral for any continuous spectra operator should be OK -- surely wavefunctions absolutely squared are Lebesque integrable. Technically a point in a compact Borel set (if I remember right, Borel sets are compact) has measure zero, so we'll have to be satisfied with the probability of finding a neighborhood of he appropriate point. For all pratical purposes, standard measure theoretic probability is perfectly adequate for your question.
Regards,
Reilly Atkinson
Why should Borel sets be compact? R^n is Borel in R^n for all n, isn't it? (I'm not sure, this is an actual and not retorical question. haven't taken measure theory yet, only next semester)
Anyway, if A is an operator with no eigenvalues (like X), how do you associate it with a wavefunction? I'm just stuck in this specific technical point.
If the state is |psi>, what's the wavefunction associated to it given A as stated above?
If we're being exact...
You should first recognize that the position operator X does not have any eigenvalues: there does not exist any λ and nonzero |ψ> such that X|ψ> = λ|ψ>.
The things we call its "eigenvectors" are really some icky objects that lie in some extension of the state space, but not in the state space itself.
I would like to assert that every self-adjoint operator has a complete set of eigenvectors in this generalized sense, but I don't know enough to assert that.
However, I can quote the spectral theorem, but first we need to learn about a spectral resolution.
A spectral resolution in a hilbert space H is a family of commuting projection operators {Eα} where α ranges over the real numbers. This family has the property that:
(1) If α < β then EαEβ = Eα.
Intuitively, this is just saying that Eα projects onto a smaller subspace than Eβ.
(2) The map α → Eα is continuous from the right.
(3) As α → -∞, Eα → 0, the zero operator.
(4) As α → +∞, Eα → 1, the identity operator.
Then, the spectral theorem says that every self-adjoint operator posesses a unique spectral resolution satisfying:
[tex]A = \int_{-\infty}^{+\infty} \alpha \, dE_{\alpha}[/tex]
in particular, |ψ> is in the domain of A if and only if the integral in
[tex]<\psi|A|\psi> = \int_{-\infty}^{+\infty} \alpha \, d<\psi|E_{\alpha}|\psi>[/tex]
converges. This integral is a Stieltjes integral.
Basically, we think of the Eα as being a "cumulative eigenspace" operator: it maps vectors onto the subspace spanned by all of the "eigenvectors" whose "eigenvalues" are less than or equal to α.
In fact, if we are working with a self-adjoint operator on a finite-dimensional space, we see that the above paragraph is literally true: we can remove the quotes.
Anyways, the connection to statistics is this: if we have a cumulative probability distribution f(a) = P(X <= a), then we would calculate the expected value of the random variable X by:
[tex] \bar{X} = \int_{-\infty}^{+\infty} x \, df(x)[/tex]
The similarity should be obvious. In fact, the conditions on the definition of a spectral resolution are precisely the conditions needed for it to be a cumulative probability distribution function!
So, it is now clear how to answer your original question. The probability that the observable A lies in some region R is:
[tex]\int_R dE_{\alpha}[/tex]
where {Eα} is the spectral resolution of A.
Wow. Thanks a million.
Only problem is, I'm not familiar yet with the integral you noted , and don't know its definition, so I got stuck at that point. I don't suppose it's a simple thing to explain?
A small question of pure curiosity: when you say, in (2), that the map needs be continuous from the right, with respect to what metric is that? Because it seems nothing promises you that E_a is bounded.
And, may I ask, what is your occupation? Into what field are you?
Thanks again.
The norm of every nonzero projection operator is 1. It's an easy proof to work out (intuitively, at least), but I'll present it if you ask.
You can skip the integral, I suppose, and write down a direct correspondence to probability:
P(A <= α | ψ) = <ψ|Eα|ψ>
which, once you've chosen |ψ>, defines A as a random variable with the given cumulative probability distribution function.
The integral itself will make much more sense when you've learned measure theory. The notation is supposed to be suggestive, though: if f happens to be differentiable, then df(x) = f'(x) dx.
Oh, and I'm a mathematician.
By the way, the reference I was using is:
Modern Physics for Mathematicians
which you can find by clicking through the "links" link from the top of the page, and a bit of digging. Appendix B is the appendix on Hilbert space, and it talks about this stuff.
Well, you've pretty much solved me the problem that's been bothering me for two weeks.
Another (related) question: in probability theory, are these kinds of structures being studied somewhere? I mean, Hilbert spaces where hermitean operators are associated with random variables, and basically all that theory used in quantum mechanics.
What should I look for in a course sylabii if I want to take that in the mathematics department? (Which I do)
Quantum physics uses all sorts of crazy mathematics from all over the board! I'm probably not the right person to ask, but I'd imagine that a good place to start is with some sort of Real Analysis course, mainly just to get a good foundation for what's to come.
Though it could very well get close to some of the topics of interest... for instance my Real Analysis text has a section on real Hilbert space in a section on Banach spaces (A Hilbert space is a type of Banach space), and it talks a good bit about bounded linear operators on a Banach space.
Courses will vary in what they teach exactly and will be called different things in different places. For example, the first course I ever did that was called real analysis did not go into details about Banach spaces, etc. It pretty much started with set theory and topology, and worked through to vector spaces, using only the basic machinery needed for analysis (effectively integration) on the reals. WIth luck, your course catalog has some decent descriptions of content. Otherwise, find out what textbooks are recommended and wander through your university's bookstore and browse the books.
The actual mathematics you NEED to do quantum physics depends on what exactly you want to do with it. For day-to-day use, you might not need anything substantial. But if you really want to get into the foundations, then you'll need some probability and measure theory, for example. The measure theory will get you into the other types of integrals. For certain purposes, you'll want some group theory (especially when it comes to understanding angular momentum as a first stop).
One thing to note is that you might learn the mathematics in courses that never make the connections to quantum physics, and the quantum physics courses you take might not ever require the mathematics you learned in the other courses. This basically reflects the fact that to just "use" quantum physics, you don't necessarily need much of the mathematical machinery that sits behind it.
Thank you both, and David, you've just just stated more or less what's bothering me in Physics courses.
With all due respect: The math of quantum mechanics is by no means crazy -- unless you are restrictive in the type of spaces and operators you consider. There's a huge mathematical literature based on quantum theory or dealing with similar issues.`. Some examples:
Compact Quantum Metric Spaces by Prof. Marc Rieffel of Berkeley, my college roommate.
http://lanl.arxiv.org/abs/math.OA/0308207 (has many references)
George Mackey's classic work on unitary representations and commutation rules.
The entire field of Distribution Theory, one way to deal with unbounded operators.
A good bit of functional analysis
Of course X has eigenvalues(characteristic values), and eigenstates (characteristic functions). And the mathematical literature is full of references to eigenstates, and eigen values. What makes them "icky"? X has no eigenvalues? Where does this come from?
To make life simple and direct, I'll quote from Hille and Phillips, Functional Analysis and Semi-groups (1953, American Mathematical Society) -- I learned my functional analysis from Prof. Phillips.
In Chap. XIX, Translations and Powers, they examine, among other things, translations in the complex plane (hence along the real line). the infitesimal generator of such translations is d/dt, as in dz(t)/dt= Lz(t), or in finite form T(a)z(t)=z(t+a) ---- think of z as a wave function, if you want, and t as time, or space, or ...
They say; "...the spectrum of d/dt considered as an operator on C[0, infinity], is precisely the half-plane R(L) <=0, the points on the imaginary axis except for L=0 are in the continuous spectrum and the rest of the half plane is in the point spectrum. To each characteristic value L corresponds essentially only one characteristic function, x(t)=exp(Lt)."
(page 532)
(C stands for comples, R for real, and x=Re(z) )
My comment about the compactness of Borel sets is wrong. Borel sets obey a sigma algebra, which is closed under finite and countably infinite unions and intersections. Measures are then defined on sigma algebras, which guarantee the additivity property necessary for measures and probability. Typically in physics we deal with Hausdorff spaces, and compact sets in Hausdorff spaces are necessarily closed, while sigma algebras contain both open and closed sets.
The classic work on measure theoretic probability theory is Cramer's Mathematical Methods of Statistics, which is nucely summarized in; ttp://cscs.umich.edu/~crshalizi/reviews/cramer-on-math-stat/
The math of QM, in my opinion is very elegant, cf Dirac, and, to be sure, it often is based on intuition. But good physics creates good math. The problems of unbounded operators and such were largely solved 70-80 years ago. More recently physicist have pushed the boundaries of topology, and given mathematicians grist for their mill.
If you look carefully, hurkyl and I end up in the same place.
Again, the math of QM is anything but crazy -- mind bending as it may be sometimes. (To see this in detail requires the intro course in real variables, and at least one more in functional analysis to get the tools necessary to make you feel sane.)
Regards,
Reilly Atkinson
I feel compelled to say that I didn't mean "crazy" as any sort of sleight: I was trying to refer to just how much high-powered mathematics is used to put various techniques used in QM on a rigorous foundation.
Which field in particular deals with such an approach to physics? That is, a mathematical rigorous approach? Is that exactly what mathematical physics is all about?
so what is now with the position operator and eigenvalue problem?..as far as my (poor) understanding goes it's like this:
In a time-independent problem, we are looking for energy eigenstates, given the Hamilton operator. There are operators that commute with the Hamilton (that have common eigenstates with H). X does not. So there is no eigenvalue problem with the X operator and statevectors as its eigenkets.
There's a bit of semantics going on here.
Normally, we speak of the states of a system living in a Hilbert space.
For example, we might say the state space is the set of all wavefunctions.
Now, the position operator X does not have any eigenvectors in this Hilbert space. (And thus, X has no eigenvalues when operating on it)
The things that we like to call the eigenvectors of X actually live in a messy thing called a rigged Hilbert space, which is your Hilbert space plus some additional things that are a pain to rigorously define. Operators on the Hilbert space can be extended to operate on the rigged Hilbert space, and when we extend X in this way, we find that it does have some eigenvectors in the rigged Hilbert space.
But, the rigged Hilbert space is a much more difficult thing to treat rigorously, so if you can avoid invoking it, you're often better off.
A couple of questions:
1. Is the uncertainty principle valid for states in the rigged Hilbert space? (There's a good reason for the question)
2. To repeat my question from the precedent page, what specific area treats mathematical rigorous approach to physics? This is exactly what I'd like to apply to in Graduate School, when the happy day comes.
The uncertainty principle doesn't really care about states: it's essentially just a theorem about operators.
However, the very thought about trying to apply it when we're considering the rigged Hilbert space makes me uneasy, because I don't know how to make sense of <φ|ψ> when |φ> and |ψ> are arbitrary elements of the rigged Hilbert space.
I think I suggested a real analysis course before... but as was mentioned, what is considered "real analysis" varies. The main topics I think you would like to have in such a course for your purposes are generic Banach spaces and generic measures. (Not just the Lesbegue measure!) Beyond that as a starting point, I don't really know. (Certainly some functional analysis, I suppose... that's a whole course on its own isn't it?)
But as I mentioned, I'm not really the person to ask. Most of what I know about quantum stuff is self-taught, and that includes a good deal of the mathematics too.
I didn't mean what courses, I meant what area in physics or mathematics- like mathematical physics, or applied mathematics.
Why does the uncertainty principle not care about states? Given two observables A and B, and a state |psi>, we have:
stdev(A)*stdev(B)>|<psi|[A,B]|psi>|
I can prove that if the uncertainty principle is valid, then X has no eigenvectors.
Correction: I don't even need the principle of uncertainty. I only need that an inner product indeed exists on the rigged Hilbert space. Does it (exist)?
That's what I was addressing in #19. I don't know how to make sense of <φ|ψ> when both |φ> and |ψ> are arbitrary elements of the rigged Hilbert space. I know what it means if one of them is a test function, and I think I even know what it means when one of them is an element of the Hilbert space, but I don't know what it means in the general case, if sense can even be made of it at all!
No knowledge of the states are needed at all to derive the HUP -- just that the operators on them are linear. I would be entirely unsurprised if you could actually formulate the HUP with no reference to states whatsoever.
Interesting. Thank you.
And you seem not to want to answer my now third time repeated question- is it mathematical physics that I want to apply to? :)
I already said twice I'm not the person to ask. :-p
I took it in a different context, I apologize.
Thanks for all the answers.
How time flies since my training. I've never before heard of a "rigged" Hilbert Space. After a brief session with Google, it appears to be a rigorous attack on combining distributions and normal L2 Hilbert Spaces. And, it justifies common practice in physics, delta functions and so forth. There's a long history of physicist's intuition driving formal mathematics; and vica versa, particularly in modern approaches to General Relativity and string theory.
Courses: follow the math program for a PhD in analysis. I'll note that many physicists learned their Banach Spaces, Lie Groups, cohomology, ... on their lonesome-- there are many books to study. And, some never bothered, being content with an intuitive approach.
Regards,
Reilly Atkinson
Regards,
Reilly Atkinson
Hey Marc Rieffel was my professor last year and I'll be taking more classes with him next year (for this year I'm studying in Berlin). I'm very interested in Quantum Mechanics from a mathematical perspective (so in effect, I'd like to be a mathematician instead of a physicist), and will probably continue studying that in grad school. I don't know if I'd be able to continue studying at Berkeley for grad school, but if so, studying more with Rieffel would definitely be a welcome possibility.
edit:
Well the math does get very overwhelming. I have the mind of a mathematician so all the "intuitive" explanations by physicists of what are non-intuitive mathematical problems don't really cut it for me. This is in some ways more of a curse than a blessing for me. I've been directly studying from a mathematical standpoint the required knowledge to really understand quantum mechanics mathematically for the past few years, and I still don't get far in a physics book before I get lost in the formalism (ie. using Dirac notation and forgetting why you can do all the things you do and pretty much leaving everything undefined). I know that a few years isn't that long a time in this subject, but it's enough time to gain respect for the mathematical development behind the scenes. I'm now sort of getting back into trying to mathematically understand quantum mechanics for myself (I took a hiatus and only focused on the math...I went through one of the classic "i hate physicists and their ambiguity" phases of math students) and hopefully I'm a little more ready to attack the problem.
  • · Replies 31 ·
  • · Replies 32 ·
