Originally Posted by vincentm
Well aren't they considered messy eaters meaning they consume more than they can chew, hence the reason for the acretion disks that are formed?
Accretion disks form primarily because of the conservation of angular momentum. A
black hole cannot simply "pull in" a clump of gas if that gas is moving perpendicular to the line between it and the black hole. Instead of fall in, the gas will tend to orbit around it, much like the planets orbit the sun. However, angular
momentum can be transported from one object to another, so if that gas can give its
angular momentum away to some other object (usually more gas), then it can fall in closer to the black hole. The exact mechanism by which the angular momentum is exchanged is still a matter of debate, but most astronomers think it has to do with magnetic fields.
but say for instance that one is formed in a binary system in which one of the 2 stars collapses, and acretes matter from the other stars, and after which there is no other matter to consume, will it just die out?
Eventually, but not for a very long time. Black holes evaporate by way of
Hawking radiation.
This i have read and that makes sense to me, they become super massive black holes?
The distinction between stellar mass black holes, supermassive black holes, and intermediate mass black holes is pretty arbitrary. I would say that a stellar mass black hole is one with less than about 100 solar masses and a supermassive black hole would be one with more than about a million solar masses.
I apologize, but on this, can you elaborate?
Because of their strong gravity, black holes can induce large tidal forces on nearby objects. If it's close enough to the black hole, a star can be tidally disrupted (torn asunder) and "swallowed" by the black hole.
this i haven't heard of, yet
We're still not sure what "dark energy" is, but in some theories (like quintessence), it could be due to some scalar field. This would mean that the dark energy could be accreted by the black hole. Here's one such reference that discusses this issue:
Bean & Magueijo 2002
