Lipschitz Continuity and Uniqueness
A differential equation that is Lipschitz continuous guarantees a unique solution, but uniqueness does not imply Lipschitz continuity. Hendrik's inquiry revealed that a first-degree differential equation, specifically of the form \(\dot K(t) = F(K(t))\) with \(F(K) = K^\alpha\) (where \(0 < \alpha < 1\)), can yield multiple solutions at \(K = 0\) due to the lack of Lipschitz continuity. The discussion references a paper by Bernis and Qwang, which addresses the implications of Lipschitz continuity on solution uniqueness.
  • Understanding of differential equations and their properties
  • Familiarity with Lipschitz continuity and its mathematical implications
  • Knowledge of first-degree differential equations
  • Basic concepts of uniqueness in solutions of differential equations
  • Study the implications of Lipschitz continuity in differential equations
  • Research counterexamples to Lipschitz continuity and uniqueness
  • Examine the paper by Bernis and Qwang for deeper insights
  • Explore advanced topics in differential equations, such as existence and uniqueness theorems
Mathematicians, students of differential equations, and researchers interested in the properties of solution uniqueness and continuity in mathematical analysis.
Kajsa_Stina
Dear all,
If a differential equation is Lipschitz continuous, then the solution is unique. But what about the implication in the other direction? I know that uniqueness does not imply Lipschitz continuity. But is there a counterexample? A differential equation that is not L-continuous, still the solution is unique?
I would really like to know the answer to this question.
Thank you all for your help,
Hendrik
Now I have found an answer to my question:
http://archive.numdam.org/ARCHIVE/A..._1996_6_5_4_577_0/ AFST_1996_6_5_4_577_0.pdf
or, rather, Bernis and Qwang have found an answer. However, my differential equation is only of first degree, like
\dot K(t) = F(K(t))
One example would be F(K) = K^\alpha with 0 < \alpha < 1, then you get multiple solutions if you start from K = 0. But that's not surprising, because the differential equation is not Lipschitz continuous in K = 0. My question now would be: Is it possible to have a unique solution even if F were L-continuous in 0?
Thanks, many greetings,
Hendrik
  • · Replies 0 ·
