Can You Solve These Physics Problems on Constant Acceleration?
  • Thread starter Thread starter Meteo
    Couple
The discussion revolves around problems related to constant acceleration in physics. The first problem involves two cars racing with different accelerations and a head start, while the second problem concerns a weather rocket's launch and its motion under gravity after the motor stops.
  • Mixed
  • Participants discuss the application of equations of motion for both problems, with some attempting to calculate times and distances for the cars and others focusing on the rocket's acceleration and velocity at a specific altitude. Questions arise regarding the relevance of mass in the rocket problem and the interpretation of variables in the equations.
Some participants have provided guidance on how to set up the equations for both problems, while others are exploring different interpretations and calculations. There is an ongoing exchange of ideas about the correct approach to take, particularly for the rocket problem.
Participants note confusion regarding the use of certain variables and the implications of the rocket's mass. The second problem specifies finding both the acceleration and the velocity at a certain altitude, which has led to varied approaches and calculations.
Meteo
Right now I've only learned 3 equations dealing with constant acceleration
[tex] v_f=v_i+a_s\Delta t[/tex]
[tex] s_f=s_i+v_i\Delta t+1/2a_s(\Delta t)^2[/tex]
[tex] v_f^2=v_i^2+2a_s\Delta s[/tex]
Ok first problem:
A Porsche challenges a Honda to a 400-m race. Because the Porsche's acceleration of 3.5m/s^2 is larger than the Honda's 3.0m/s^2, the Honda gets a 50-m head start. Both cars start accelerating at the same instant.
Who wins?
I used the 3rd equation to get 2800 and then sqrt 2800 to get Vf=53. Then I used the 1st equation to get delta t. Which I got to be about 15.14 sec. For the Honda I did the same thing and got 15.33 sec. So the Porsche wins. I was wondering. Did I do this right?
The second question...
A 1000kg weather rocket is launched straight up. The rocket motor provides a constant acceleration for 16s, then the motor stops. The rocket altitude 20s after launch is 5100m. You can ignore any effects of air resistance.
This one completely stumped me. Cause no matter which equation I use, I get at least 2 variables... and is the 1000kg even important?
For the first one, you can use the second equation.
I'll indicate p for the posrche and h for the honda.
[tex]s_p=\frac{3.5 \cdot (\Delta t)^2}{2}[/tex]
[tex]s_h= 50 + \frac{3.0 \cdot (\Delta t)^2}{2}[/tex]
Now you could subsitute their final positions being 400m and see which ones needs the least time.
What is the question for problem 2?
For problem2.
The rocket lifts off with a high acceleration (I got about 27 m/s²) for the first 16s reaching a velocity of v1. It then travels under gravity effects only for the next 4s reaching a velocity of v2 (v2 =/= 0).
You have,
v0 = 0 at t = 0 and s = 0
v1 = v1 at t = 16 and s = s1
v2 = v2 at t = 20 and s = s1 + s2
where s2 is the distance traveled under gravity effects only.
You can now use your eqns of motion to eliminate v1 (or v2) and the unknown initial accceleration and using the fact that s1 + s2 = 5100m.
I don't know what the question is supposed to be for this question, but knowing v1 and v2, you should now be able to answer it.
Edit: I don't see where the mass is needed for this Q.
s instead of x? him I've never seen that variable change on those motion equations.
The questions for problem 2 were find the acceleration of the rocket, then find the velocity as it passes 5100m.
I labeled
v0=t0=y0=0
y2=5100
t1=16 t2=20
Using the equations I got
V1=16a
Y1=128a
I then used the 2nd equation
[tex]5100=128a+16a(4)+1/2(-9.8)4^2[/tex]
I get a=26.9 :smile:
I don't know where to go from here.
Im not sure how to use s1 + s2 = 5100m.
You don't have to go very far from here now.
You've already used s1 and s2, in effect.
s1 = ½a(16)²
s2 = v1(20-16) - g(20 - 16)²
s1 + s2 = ½a(256) + 4v1 - g*4²
5100 =128a + 4(16a) - g*4² since v1 = at1 = 16a
To get the velocity at 5100,
vf = vi - gt
This is the eqn of motion in free fall, under gravity effects only, where vf is the velocity at 5100, vi is the initial velocity (= v1) at the start of its travel under free fall and t is the time taken, during free fall, to reach the height of 5100.
9K
  • · Replies 42 ·
