Calculating Resultant Force Vectors in a 2D System
The discussion revolves around calculating the resultant force vectors acting on a charged particle located at one corner of a square, where four equally charged particles are positioned at each corner. The participants explore the effects of these forces in a two-dimensional system.
  • Participants discuss projecting forces onto axes and resolving vectors into components. There is an exploration of how the forces from multiple charges interact and contribute to the resultant force vector. Questions arise about the representation of vectors and the confusion surrounding the number of components in a 2D scenario.
The conversation is ongoing, with participants sharing insights on vector resolution and the nature of force interactions. Some guidance has been provided regarding vector addition, but confusion remains about the interpretation of components and their representation in the context of the problem.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on understanding rather than providing direct solutions.
ranger
Lets say that we have a four positive and equally charged particles. They are located on the corners of a square.
Can someone show (by diagram) how the other three particles would affect anyone particle. Please show how you reslove the vectors into its componets and how you get the resultant (formulas please :smile: ).
--thanks
Projecting the forces onto axes:
say we choose two axes parallel to the sides of the square, then if the square side length is a, each one of the two charges on the axes will apply force equal to q^2/a^2 on its axis and 0 on the second one, and the charge on the diagonal will apply sin(pi/4)*q^2/(sqrt(2)a)^2=cos(pi/4)*q^2/(sqrt(2)a)^2=q^2/(sqrt(2)a^2) on each one of the axes
The force vectors on a point charge operate along the lines determined by the point charge and each of the other charges. If charges are opposite, the vector will point toward the other charge, and if the charge are the same sign, the vector will point away.
Okay then, so since the charges are the same, they would repel. I've put together a little image based on that.
http://img356.imageshack.us/img356/3092/vector1mb.png
Now I want to calculate the final position and magnitude of the particle that is being acted upon. For that I need the resultant vector. But how do I get that? It looks like the brown charge is in the place of where the resultant sould be. I'm thinking tail-to-tip here. This is getting very confusing.
The resultant force vector is the sum of each force vector contributing to the force.
So if one has 3 vectors (i, j, k are orthogonal unit vectors).
a1 i + a2 j + a3 k
b1 i + b2 j + b3 k
c1 i + c2 j + c3 k
then the resultant vector is simply
(a1 + b1 + c1) i +
(a2 + b2 + c2) j +
(a3 + b3 + c3) k
Since the problem is 2D (coplanar), the coefficients of k are zero
:smile:
a1 i + a2 j + a3 k
b1 i + b2 j + b3 k
c1 i + c2 j + c3 k
(a1 + b1 + c1) i +
(a2 + b2 + c2) j +
(a3 + b3 + c3) k
:smile:
I'm still knida confused. I see that you have a1 + b1 + c1, what do thoes mean. Did you reslove them into conponenets? If you did then how come you have 3 components? Arent we just using x and y axis.
thanks again
  • · Replies 38 ·
