How does impulse travel in our nerves
  • Thread starter Thread starter benzun_1999
    Impulse Travel
The discussion centers around the mechanisms of how nerve impulses travel within nerve cells, including the generation of action potentials and the factors influencing their speed. Participants explore biological principles related to nerve function, including ion concentrations and membrane potentials.
  • One participant describes the resting potential of nerve cells, highlighting the differences in ion concentrations inside and outside the cell, which create a negative internal environment.
  • Another participant elaborates on the process of action potential generation, detailing the roles of Na+ and K+ ions during depolarization and repolarization phases.
  • It is noted that the Na+/K+ pump is crucial for maintaining ion gradients, consuming significant energy in neurons.
  • One participant emphasizes that action potentials are "all or none" events and propagate along the neuron, with speed varying by fiber type, mentioning myelinated versus unmyelinated fibers.
  • A participant raises two questions regarding the speed of impulse travel and the possibility of converting electrical impulses into nerve impulses.
  • Responses indicate that the speed of nerve impulses depends on the type of nerve fiber, with specific speeds provided for A, B, and C fibers.
Participants generally agree on the basic mechanisms of action potential generation and the role of ion movement, but there are varying levels of detail and emphasis on different aspects of the process. The discussion includes multiple viewpoints on the specifics of impulse speed and the nature of nerve impulses.
Some participants mention complex concepts such as the Nernst equation and Donnan equilibrium without fully explaining them, indicating potential gaps in understanding or assumptions about prior knowledge.
This discussion may be useful for individuals interested in neurobiology, physiology, or those seeking to understand the fundamental processes of nerve impulse transmission.
benzun_1999
hi all,
I dontn know much in biology. The way messages are transmitted in our nerves has always amazed me. Can anyone explain how does impulse travel in our nerves.
-benzun
All For God
Biology news on Phys.org
My memory is vague but I remember the general principle.
You are talking about how a nerve generates an action potential. How an impulse travels within our nerves.
The intracelluar milieu of nerve cells contain high concentrations of organic anions and inorganic cations mainly high K+ and a lower concentration of N+ and CL-. In the extracellular fluid outside the nerve cell, the concentrations of K+ are low and those of Na+CL- are high...the opposite of the intracellular environment. The result is a difference in potential across the membrane called resting potential with the inside of the cell being strongly negative compared with the fluids outside the cell.
During impulse transmission, there is a change in the resting potential and a flow of electric current across the membrane. This is the action potential. It is essentially a very rapid depolarization (decrease in negativity of the inside relative the positive outside) and a somewhat slower repolarization to the resting potential.
At the peak of the action potential the inside of the cell becomes positive with respect to the outside. How does this happen? First, there is an initial inward current due to the influx of Na+ and subsequently an outward current due to migration of the K+ from inside to the outside. This initial depolarization causes Na+ conductance to begin to increase, which depolarizes the membrane further and this increases Na+ conductance and so on. Repolarization then occurs when the K+ efflux restores the internal negativity. These passages of Na+ and K+ are thought to occur through separate channels in the cell membrane. Other ions cross the membrane during the action potential such as Ca++ etc. but that gets more dettailed. Of course, I did not get into the transmission across synapses.
That is a basic description without all the different equations Nernst equation, Donnan equillibrium, crap that I can't remember.
Adrenaline you got most of the stuff rigth. K+ and Na+ are actively pump across the membrane against their concentration gradient which requires a huges amount of ATP. 2K+ in 3NA+ out for 1 ATP. The pump runs continuously and spend 70-80% of the neurons energy. K+ diffuse out of the of the cell and Na+ diffuse back in. Overall, there is more are greater K+/Na+ concetration going out then going in. Therefore the outside of the cell become positive and the inside has a negative charge in part due to the protein content. There is an equilibrium that is reach and the resting membrane potential (RMP) is -70 mV.
Then come the action potential. The first step is excitation. This trigger the action potential. The voltage rise from -70 mV to -50 mV. -50mV is the threshold limit. This is due to an increase Na+ in the cell. When the threshold is reach, depolarization occures. It goes from -50mV to +30mV. The Na+/K+ pumps stop, Na+ gates open, Na+ rushes in. Then the cell repolarize. It goes from +30 mV to -85 mV. Voltage sensitive K+ gates open, K+ rushes out of the cell. At midpoint Na+ gates close and Na+/K+ pumps restarts. The last step is Hyperpolarization. Voltage rise from -85 mv to -70 mV. This is the slowesst phase. K+ gates close, Na+/K+ pumps are running and RMP is restore.
Action potential is all or none. Once it is initiate is goes all the way to the end of the neuron. The Action potential propagates along the nerve cell because Na+ spread in the cell, some Na+ spreads down the cell and ajacent membrane are less +ve/-ve and it reach RMP.
Action potential also spread faster in myelenated fibers. Also large diameter fibers can fire up every 0.4 msec (2500 action potential per sec. Small diameter fiber is every 4 msec (250/sec)
I have 2 questions-
1)how fast does this impulse travel?
2)is it possible to convert electric impulse into nerve impulse?
-Benzun
All For God.
Dependent on the nerve fiber type
A Fiber:
largest diameter, all myelinated
Fastest fiber - 125 m/sec
B fiber:
Mid size fiber, myelinated
speed up to 10m/sec
C fiber:
smallest fiber, unmyelinated
speed up to 0.5m/sec
  • · Replies 19 ·
10K
  • · Replies 43 ·
