| Thread Closed |
Graphics |
Share Thread | Thread Tools |
| Sep9-05, 12:36 AM | #1 |
Graphics
Is there a way to create graphics in C++. or in some other language, and I can use the grphic file in the C++ source code?
| Sep9-05, 12:41 AM | #2 |
also, how could I put a code with another language in the middle of a C++ document?
| Sep9-05, 01:47 AM | #3 |
If you're using Windows, you could use the GDI through the Windows API or through the MFC classes, or you could use DirectX or OpenGL for 3D high-speed graphics. You could also use any number of available libraries, SDL for example. In Linux, you're gonna have to go through the X libraries (not recommended). Probably you should use some toolkit, like the Qt libraries. For 3d graphics, you can use OpenGL, or OpenGL + SDL (thats what I use).
Also, I don't get what you mean by embedded another language into a C++ document. If you mean whether you can embed code from another language into a C++ source file, then no, unless you translate it to C++, because the compiler only compiles C/C++ and not any other language. However, most compilers do support some form of embedded assembly language. The MSVC compiler uses the "__asm" keyword I believe. In gcc/g++ it would be asm("...") |
| Sep9-05, 02:30 AM | #4 |
Graphics
you can embed matlab too apparently.
| Sep9-05, 05:47 AM | #5 |
Recognitions:
cefarix, your going a little overboard.
If you simply want to create and edit images then use this: http://www.boutell.com/gd/ |
| Sep9-05, 03:32 PM | #6 |
| Sep9-05, 03:52 PM | #7 |
Recognitions:
You mean she. Also GD is written in C so it works with C++.
| Sep10-05, 10:08 AM | #8 |
Why not do some really enjoyable stuff with graphics and play some games?
Try allegro http://www.talula.demon.co.uk/allegro/ Its enjoyable and easy to play around with (well atleast i found it easy to play around it, so i may be generalising a bit too much here). There are lots of demos to help you around. -- AI |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Graphics
| Graphics cards. | Computing & Technology | 3 | ||
| Graphics with Onboard Intel Extreme Graphics 2 on ASUS P5PE VM | Computing & Technology | 8 | ||
| New graphics card | Computing & Technology | 22 | ||
| PCI graphics card? | Computing & Technology | 3 | ||
| game graphics | Computing & Technology | 12 | ||
