Double-Slit Question - PLEASE HELP
  • Context: Undergrad
  • Thread starter Thread starter Codeman
    Double-slit
The discussion revolves around the practical setup and requirements for conducting Young's Double-Slit Experiment using a 4X5 camera. Participants explore the necessary dimensions for the slits, the impact of using natural versus monochromatic light, and the implications of adjusting distances between the slits and the ground glass.
  • Homework-related
  • One participant requests assistance in determining the size and spacing of double-slits for a specific experimental setup involving a camera.
  • Another participant cautions that using natural light may complicate the interference pattern due to overlapping frequencies and suggests the need for a coherent light source.
  • There is a discussion about the necessity of using a filter to achieve monochromatic light, with one participant suggesting a green optical filter while noting potential issues with brightness.
  • A participant mentions the importance of preparing the setup adequately before cutting the slits and suggests obtaining slits from a commercial supplier.
  • Another participant provides links to resources that may help in calculating the necessary parameters for the experiment.
  • One participant emphasizes the importance of careful planning and measurement before proceeding with the project.
Participants express varying views on the feasibility of using natural light and the steps necessary to prepare for the experiment. There is no consensus on the best approach or the specific requirements for the slits.
Participants mention the need for coherence in the light source and the potential challenges with exposure times and brightness when using filters. The discussion reflects a range of assumptions about the setup and the physics involved.
Codeman
Hi all,
I am not educated in physics but truly need someone who greatly understands Young's Double-Slit Experiment to contact me directly at cteditions@aol.com. I need to figure out what size slits (and distances between slits) I need for a particular setup with a 4X5 camera. If I know the distance from the double-slit plate to the ground glass I need information on what I can expect as far as interference patterns.
Since the double-slit plate will be mounted where the lens normally would be, what will happen when I move the lensboard closer and further from the ground glass?? I will be using natural light but can't I use a filter to make it monochromatic light? And what is best filter?
This is NOT a school project. I need to get this information to the company that is cutting the slits! I really need the HELP...
Please help if you can.
Much appreciation,
Cody Thomas
You might have trouble doing this with natural light. If you use a broad-spectrum source, like natural light, all the different frequencies will have overlapping interference patterns and you won't clearly be able to distinguish between them.
If you just try to filter it with a sufficiently narrow-band filter, you will probably find the intensity could be too low, depending on exactly what exposure time you plan for.
I probably should have mentioned first that you will need to make the source coherent--natural light won't be. You would need to pass it through a single slit first, etc. If you don't know what I mean by this paragraph, then you are probably going to have to do quite a bit more preparation before you conduct this experiment.
The particular slit characteristics you choose will depend on the frequency of light you choose and the specific geometry of your setup. You might find it easier to obtain the slits from a commercial educational scientific equipment supplier...
It sounds like you are going to have to do a bit more preparation before you get to the point of having the slits cut.
David,
I know that I will need to use a filter so that the entire visible spectrum does not pass through the slits. And there is no problem with exposure as I do not need to "capture" anything in a quick manner.
I understand that I will need a single slit in front of the double-slit but I need to have the double-slit cut first as it attaches to the lens mount of the camera... I can add a pinhole in front of the double-slit (at any distance necessary) at a later date... I need help finding the size and spacing of the double-slits given a particular distance between double-slit and screen and a particular width/length of screen. PLEASE HELP ANYBODY...
Thanks again,
Cody
Maybe these would help you calculate the numbers? :smile:
The diagram appears when you start altering values, I think:
http://schools.matter.org.uk/Content/Interference/laserinterference.html
The "s/mm", "b/mm" and "D/m" are just a fussy way of saying they mean "millimeters" for the distances between the slits, "millimeters" for the width of the slits and "meters" for the distance to the screen. :rolleyes:
Anyhow, it shows you what you can expect when you alter the various distances.
Scrolling down, here's a calculator for this kind of experiment as well:
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/slits.html#c1
Measure twice, cut once Codeman.
Sound project management requires that you work out the details
before you submit the purchase orders. This might be a lesson that's
even more valuable to you than the diffraction of waves.
P.S. Go to Edmund Optic's website and look for a green optical filter.
You can use this but it won't be very bright because if you take white
light and filter out a near-monchromatic color, it will be quite dim. That's
why most folks use lasers. If you get a laser, be very careful with it. It
can damage your eyes.
  • · Replies 19 ·
  • · Replies 65 ·
  • · Replies 33 ·
  • · Replies 110 ·
9K
  • · Replies 33 ·
