Planes Calculation Help: Find Point of Intersection with Coordinate Planes
The discussion revolves around finding the point of intersection of a line with the coordinate planes. The line is defined by a point and is parallel to another given line, with specific focus on the xy-plane, yz-plane, and xz-plane intersections.
  • The original poster attempts to determine the intersection with the xy-plane by setting z=0 but expresses uncertainty about solving for x and y. Some participants suggest solving for the parameter t to find the intersection points.
Participants are exploring different interpretations of how to find the intersection points. There is an indication that some guidance has been offered regarding the need to establish the line's equation first and the condition for the z-component when intersecting the xy-plane. However, there is no explicit consensus on the correct approach or solution yet.
The original poster mentions confusion about the calculations and results when substituting values back into the equations, indicating potential gaps in understanding the relationship between the parameters and the coordinates.
Whatupdoc
Consider the line which passes through the point P(-3, -4, 3), and which is parallel to the line x=1+6t, y=2+4t,z=3+1t
Find the point of intersection of this new line with each of the coordinate planes:
xy-plane:(_,_,_)
yz-plane:(_,_,_)
yz-plane:(_,_,_)
to find xy-plane, I am thinking that i need to set z=0, but I'm not extactly sure how i would solve for the other two points(x & y). can someone help me?
When the line intersects with the xy plane, it will have z=0. Here you can solve for t.
1+6t=2+4t
t=1/2
and when i plug that 1/2 back in for the x and y equation, i get the wrong answer. I'm not understanding what you are trying to tell me.
Find the equation of the line parallel to the one given that goes through that point first. Then notice that When it intersects the xy plane, the z component of the line will be 0.
