Solve Tension Problem: mgsinθ Answer
  • Thread starter Thread starter prettybabylily
    Tension
The discussion revolves around a tension problem involving a string and a box, where the original poster expresses confusion about the relationship between tension and the angle theta. The context includes a setup where the string is attached to a wall, and the box is influenced by gravitational forces.
  • The original poster attempts to determine the tension in the string and questions the validity of their initial expression for tension. Participants explore the equality of angles theta and beta, and some discuss the implications of tension being uniform along the string.
Participants are actively engaging with the problem, questioning assumptions about angles and the nature of tension in the string. Some guidance has been offered regarding the equality of tension along the string, but no consensus has been reached on the overall solution or approach.
There is a mention of the absence of friction in the system, which may influence the discussion on tension and equilibrium. Additionally, the original poster's reference to a specific answer source indicates a desire for verification rather than direct solutions.
prettybabylily
Can anyone help me solve this problem that i am a little confused about? i think the answer is tension=mgsin"theta", am i close at all?!
thanks!
According to the picture, from point A to point B is a string that is attached to wall. The string is twice the distance from Point A to Point O, and Point A to Point O's distance is the same as the distance between Point B Point O. If i put k upto the string, which has a box M that is attached to it. when it stops rolling on the string. what is the Tension on the string? (no friction applied)
just click the webpage below to check the answer,but I only provide answer for tension,since I am sure you will be able to find where the box stops sliding ,after you can find tension.hope it will benefit you
http://www.angelfire.com/ultra/reinhard
thank you!
thank you so much for your help!
hi, what i don't understand is how do you know that theta equals to beta? the 2 angels i mean.
thanks
lily
btw, i like your icon, vic is =)
α and β are the same because:
The tension from K to A must be equal in magnitude to the tension from K to B because they are the same piece of rope and the horizontal components of the tension must cancel.
yes, that is what i thought. as long as it is the same rope, then tension anywhere should be the same on the rope. but is there anyway that i can proof this theory.
it is proved by observation.
the system more or less is like pulleys
(note:observation only focus on string and the ring H)
in the system,the moving part is actually the ring,but relative to ring ,the string is moving.
relative to the ring the string will keep moving until the tension in the string balance.because if the tension is not the same,then there will be net force produced ,which cause the string moves.
(now we look from particle view)
(note: open the graph attachment now)
don't forget that string also made up of particles.the graph is a picture of a string which is broken down into 4 particle for simplicity.
***now look at the third particle
the forth particle attract the third particle with F6 N and second particle attract thrird particle with F5 N
since the string in equilibrium,it implies that the third particle does not move,and it happens if F5=F6
***now look at the second particle
the third particle attract the second particle with F4 N and first particle attract second particle with F3 N.Also since the string in equilibrium,it implies that the second particle does not move,and it happens if F3=F4
***we know that attraction second particle to the third particle should be the same with the attraction of third particle to the second particle.That is to say F4=F5
so F3=F4=F5=F6 and so on along the string.
hence ,because the attractions between particles along the string are the same so we can conclude that the tensions along the string are the same(provided friction force neglected).
I hope they are clear
anyway how do you know vic chou?which country are you from? =)
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 16 ·
