Solving Electromag Homework: Can You Help?
  • Thread starter Thread starter notmetalenough
    Homework
The discussion revolves around a problem in electromagnetism involving three charged beads, where the objective is to find the position of a third bead that balances the forces exerted by two fixed charges. The original poster is attempting to derive a formula for the position of this bead in relation to a given distance d.
  • The original poster presents a mathematical setup involving the forces acting on the third bead and attempts to solve for its position. Some participants question whether the goal is to find the equilibrium point where forces cancel out or the electric field is zero. Others express uncertainty about the correctness of the original poster's calculations.
There is mention of a specific requirement for the answer format, which impacted the original poster's ability to submit their solution successfully. The discussion also touches on the need to express the position of the third charge as a ratio of d.
notmetalenough
I'm doing my first electromag homework so there will probably be a few more of these.
Two small beads having positive charges 19q and q are fixed at the opposite ends of a horizontal insulating rod extending from the origin (the location of the larger charge) to the point x = d. As in the figure below, a third small charged bead is free to slide on the rod.
So I figure that
F = ((k * 19q Q)/ x^2) - (k* q * Q)/(d-x)^2)
so 19/x^2 = 1/(d-x)^2
d-x = x / sqrt(19)
d = x + x/sqrt(19)
= x * (1+sqrt(19))/sqrt(19)
so x = d * (sqrt(19))/(1 + sqrt(19))
which would be about 0.81339
apparently it's the wrong answer. Can anyone tell me why, or where I went wrong?
Are you trying to find the point of equilibrium for the third charge? If so, it will find equilibrium at the point where the force from both charges cnacel each other out (equal each other) or when the electric field is zero. These occur at only one point and they are the same point.
right, but i have to find it as a ratio of d.
i can't find anything wrong with how i set it up, I made the charges proportional, and equal to each other and then solved for x, my answer should be sound, but the program won't accept it.
okay, false alarm. I did have the right answer, my program wouldn't accept it without the leading 0 and wouldn't tell me that that was the reason I was getting it wrong.
((k * 19q Q)/ x^2) = (k* q * Q)/(d-x)^2) is where you should start, solving for x.
  • · Replies 32 ·
