Make an External HD: DIY or Buy?
  • Thread starter Thread starter exequor
The discussion revolves around the feasibility and complexity of creating a DIY USB adapter for a normal hard drive, as opposed to purchasing a pre-made solution. Participants explore the technical requirements and costs associated with both approaches.
  • One participant expresses interest in designing an adapter to connect a normal hard drive to a computer via USB, questioning the difficulty of such a project.
  • Another participant points out that there are cheaper adapters available, suggesting that the cost should not exceed $30.
  • A third participant mentions that a more expensive option exists that includes a case, emphasizing the need for firmware to make the device recognizable as a USB device.
  • One participant warns that understanding both the USB and IDE protocols is necessary for such a project, suggesting that the effort and cost to develop a DIY solution would outweigh the benefits of purchasing a pre-made unit.
  • A later reply humorously agrees with the caution, implying that if one had the necessary knowledge, they would not need to ask about the difficulty.
  • Another participant clarifies that their inquiry was about the difficulty of the task, acknowledging the evidence presented about the impracticality of a DIY approach.
  • Participants share links to various adapter options, including a low-cost alternative found on TigerDirect.
Participants generally agree that purchasing a pre-made adapter is more practical than attempting to create a DIY solution, though there is some debate about the level of knowledge required to undertake such a project.
There are unresolved questions regarding the specific technical challenges involved in designing a USB adapter for a hard drive, including the necessary understanding of protocols and potential costs associated with development.
exequor
Ok, I have a normal hard drive and I want to connect it to my computer using a usb cord (any port i guess). There are adapters out there that allow you to do this but they cost way too much (like $165).
How difficult would it be for me to design such an adapter. I know that the drive would need power, but it is how to convert the IDE connection at the back to something usb adaptable I am unsure of.
This is one of those times where the respons is "If you have to ask then you don't know enough to begin with." Basically, you'de need to understand the USB protocol as well as the IDE protocol---both hardware and software---before even attempting such a project. You might be able to get away with an FTDI chip and/or a microcontroller(PIC and ATMEL have USB capable uC's but you still need a bus driver chip and you still need to understand the protocol(s) before making something that works) but you're just wasting your time because the cost and time needed to develope what you want would far and away exceed the cost of simply buying a premade unit.
haha that's exactly what i was thinking but didn't want to say it. If you have the knowledge to be able to do it, you wouldn't have asked if it were possible.
Pengwuino I can't remember asking if doing it was possible, in fact I know that it is possible. I asked how difficult it was to do, and faust provided enough evidence to convince me that it would be too expensive to develop it on my own.
Thanks for the links guys, I might go with the one from http://www.usb-ware.com/usb-2-ide-adapter-ud200.htm because it seems like the one at best buy is just better looking, with the enclosure and everything.
edit: i just found one on tigerdirect for $19.99
http://www.tigerdirect.com/applicat...Sku=C250-2288&SRCCODE=BIZRATE&CMP=OTC-BIZRATE
Yah but if you did have the ability to do it, you probably would have known enough to determine how hard it would be.
  • · Replies 17 ·
