Townsend
- 240
The problem says;
Suppose that a bicycle wheel of radius a rolls along a flat surface without slipping. If a reflector is attached to a spoke of the wheel at a distance b from the center of the resulting curve traced out by the reflector is called a curtate cycloid.
I need to find a set of parametric equations for the curtate cycloid.
Using vectors I found the following set of parametric equations
[tex] x=at-|a-b|sin(t)[/tex]
[tex] y=a-|a-b|cos(t) [/tex]
I would appreciate it if someone could tell me if my answer is correct since this is an even numbered problem I cannot check my answer. And don't worry...I don't have to turn this in or anything so it's not cheating...
