Need help setting up basic dynamics problem
  • Thread starter Thread starter fletch
    Dynamics
The discussion focuses on solving a dynamics problem involving a point A that oscillates with an acceleration equation of a = 2880 - 144x. The user seeks to determine the maximum velocity and the positions where the velocity is zero, given an initial velocity of 11 in/s at x = 20.4 in. The correct approach involves integrating the acceleration equation to derive the velocity equation, identifying the critical point at x = 20 in for maximum velocity, and solving for the zeroes of the velocity equation. The user’s error stems from not accounting for the phase angle or time-offset when calculating maximum velocity.
  • Understanding of basic dynamics principles
  • Knowledge of integration techniques in calculus
  • Familiarity with velocity and acceleration relationships
  • Ability to solve polynomial equations for critical points
  • Study integration methods for deriving velocity from acceleration equations
  • Learn how to identify critical points in motion problems
  • Research phase angles and time-offsets in oscillatory motion
  • Practice solving polynomial equations to find zeroes of functions
Students and professionals in physics or engineering fields, particularly those focusing on dynamics and oscillatory motion analysis.
fletch
http://fletchowns.net/incoming/picture.jpg
point a oscillates with accel of a=2880-144x. Magnitude of velocity is 11in/s when x=20.4in. Determine the max velocity of A & two positions at which velocity is zero.
Why am I getting this wrong :( It seems so easy
integrate a=2880-144x to get v, plug in 11in/s and 20.4in as the initial values, solve for the constant and you get the velocity equation. From the acceleration equation you know there is a critical value at x=20in, so plugging x=20 to the velocity equation should give you the max velocity, and the other part is just finding the zeroes of v=...is that the right setup?
Your initial value (v=11in/s) is NOT QUITE at maximum-velocity
location, so if you did not include a phase angle or time-offset,
(ending up with 20.917...) that might be your error.
umm, how do you know you're getting it wrong?
  • · Replies 19 ·
