Troubleshooting Final Balance Calculator Program
The discussion revolves around troubleshooting a Java program designed to calculate the final balance of an investment based on user inputs for initial balance, interest rate, and duration. Participants address issues related to variable definitions, input prompts, and compilation errors.
  • Homework-related
  • One participant notes that the variable ty is incorrectly defined as the initial balance instead of the number of years, and b0 is never defined in the input.
  • A later reply indicates that the participant has made corrections to the code, changing the input prompts to correctly ask for the initial balance and the duration.
  • Another participant points out that the method System.out.PrintIn should be System.out.println, highlighting a case sensitivity issue.
  • There is mention of a potential decimal point problem in the interest rate calculation, but no specifics are provided.
  • One participant suggests that the compiler issue may be due to the Java bin directory not being listed in the system path or a problem with the installation of Jgrasp.
  • Another participant recommends trying to compile the program from the command line as a troubleshooting step.
Participants express differing views on the source of the compilation issues and the correctness of the code. There is no consensus on the resolution of the compiler problem or the exact nature of the interest rate calculation issue.
Limitations include unresolved assumptions about the environment setup for Java programming and the specific nature of the decimal point issue in the calculations.
bomba923
Why won't this work? :frown:
import javax.swing.JOptionPane ;
public class FinalBalanceCalculator {
public static void main(String args[]) {
String input;
String name;
double b0;
double rc;
double ty;
double ans;
input = JOptionPane.showInputDialog("What is your name?") ;
name = input ;
input = JOptionPane.showInputDialog("What is your interest rate?") ;
rc = Double.parseDouble(input);
input = JOptionPane.showInputDialog("What is your initial balance?" );
ty = Double.parseDouble(input) ;
ans = Math.pow(1 + rc,ty) * b0 ;
System.out.PrintIn(name + "has an initial balance of $" + b0 + ",") ;
System.out.PrintIn("which is compounded annually at " + rc + "%") ;
System.out.PrintIn("After " + ty + " years, " + name + " will have exactly:") ;
System.out.PrintIn("$" + ans ) ;
}//main
}//FinalBalanceCalculator
Computer science news on Phys.org
Errors would be nice.
String input;
String name;
double b0;
double rc;
double ty;
double ans;
name = input ;
}//main
I don't program in Java so I could be missing something, but in your input you define ty as the initial balance, in the output you say ty is the number of years and b0 is never defined in the input, but is the initial balance in the output. So me thinks you need b0 for initial balance (not ty) and you need to add a statement to get the number of years (ty) in the input.
:smile: Thanx, I fixed it as :
String input;
String name;
double b0;
double rc;
double ty;
double ans;
name = input ;
b0 = Double.parseDouble(input) ;
rc = Double.parseDouble(input );
input = JOptionPane.showInputDialog("How long will you keep this money?" );
}//main
*It appears on the error sheet that there is a problem with the compiler, javac.exe
and it cannot be found. I download "JDK5.0 Update 4" and programmed with Jgrasp,
but do I need an additional compiler where I download elsewhere?
(a sort of path problem, in regards to a javac.exe missing from a "working directory")
i.e. the "I" should be an "l"
Also, you have a decimal point problem in your interest rate calculation, but you can figure that out for yourself.
I don't know anything about Jgrasp (I've never used it), but your compiler problem may be just that your java bin directory is not listed in your path (in your environment variables).
Or maybe there's some problem with your installation of Jgrasp.
Have you tried to compile from the Dos command line? Open a DOS Command Prompt window, chdir to the directory that contains your java source code and enter:
> javac FinalBalanceCalculator.java
12K
