Thread Closed
Kirchhoff's Voltage Law
Share Thread Thread Tools
Sep15-05, 09:20 PM   #1
Hi,
My question:
The batteries have emfs of E1=9.0 V and E2= 12.0 V and the resistors have values of R1=25 ohms, R2=18 ohms, and R3=35 ohms.Assuming each battery has internal resistance r=1.0 ohms find the direction and magnitude of the currents.
____R1______
E1...................|
|_____R2______|
E2...................R3
|_____________|
For this problem could I use this equation to find the currents.
V(ab)=E-Ir and I= V/R
Is this correct
Thank You
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep15-05, 09:47 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Quote by jena
Is this correct
Since you have not labeled nodes "a" and "b", it's not possible to say.
Sep16-05, 10:14 AM   #3
Please disregard the ab nodes.
Thank You
Sep16-05, 10:17 AM   #4
Recognitions:
Quote by jena
OK, even if we disregard the "ab", you still aren't going to solve this with a canned equation. You have to apply Kirchhoff's laws to the problem. I think that the easiest way to solve the problem is by superposition. That is, solve the problem once by deactivating E1 and solve it again by deactivating E2 (deactivated voltage sources are just short circuits). Then you can find the currents in each case and add the results together.
Sep16-05, 10:33 AM   #5
So it would be
I=V/R
I(1)=E1/(R1+R2)
I(2)=E2/(R1+R3)
to help find the currents needed
Sep16-05, 11:17 AM   #6
Recognitions:
No, you have to apply Kirchhoff's laws. This requires some analysis beyond simple plug-and-chug.
As I was explaining, I think the easiest way to do this problem would be to look at the following two circuits:
____R1______
|_____R2______|
|....................R3
|_____________|
and
____R1______
|_____R2______|
|_____________|
Find the current through each resistor for both circuits. Then you can add up the results for each circuit to get the current through each resistor when both sources are activated. This is called the principle of superposition, and it works because the element law for resistors (V=IR) is linear.
Sep19-05, 11:21 PM   #7
Hi,
I have the currents:
I(1)=.68 A right
I(2)=.31 A left
I93)= .18 A up
what's next
Thank You
Sep19-05, 11:58 PM   #8
Recognitions:
Jena,
if 0.68 C/sec flows into the solder-spot on the right
(where R1 joins R2 and joins R3),
then 0.68 C/sec must flow OUT of that node.
(you have (0.31 - 0.18)[Amp] = 0.13 C/sec out.)
Why would I3 flow up? only if E2 is + at bottom.
But then I2 must be large.
You Did simplify with series and parallel R's first?
Sep22-05, 11:10 PM   #9
Hi,
I tried it again and this time I set equations to find the currents using the loop rule.
Loop 1:
E1- I1(R1+r)-I2(R2), where is the r, is the internal resistance
____R1___>___
r.....................|
E1..................V
|_____R2_<___|
Loop 2:
-E2+I2(R2)+I3(R3+r), again where r is the internal resistance
____R2___<___
E2..................^
|_r____R2_>___|
Is this correct
Thank You
Sep23-05, 12:26 PM   #10
Hi,
I think I got it now, the work is below.
1. Set up loops
Loop 1: E1-(R1+r)(I1)-R2(I2)=0
9V-(25ohms+1ohms)(I1)-(18ohms)(I2)=0
9V-(26ohms)(I1)-(18ohms)(I2)=0
Loop 2: E2-(R3+r)(I3)-R2(I2)=0
12V-(35ohms+1ohms)(I1)-(18ohms)(I2)=0
12V-(36ohms)(I3)-(18ohms)(I2)=0
2. Substitution: Add Junctin equation in: I2= I1+I3
Loop 1: 9V-(26ohms)(I1)-(18ohms)(I2)=0
9V-(26ohms)(I1)-(18ohms)(I1+I3 )=0
9V-(44ohms)(I1)-(18ohms)(I3 )=0
-(44ohms)(I1)-(18ohms)(I3 )=-9V
Loop 2: 12V-(36ohms)(I3)-(18ohms)(I2)=0
12V-(36ohms)(I3)-(18ohms)(I1+I3 )=0
12V-(54ohms)(I3)-(18ohms)(I1 )=0
-(54hms)(I3)-(18ohms)(I1)=-12V
3. Add/Subtract Loop 1 and Loop 2. Solve for I3
Loop 1:18( -(46ohms)(I1)-(18ohms)(I3 )=-9V)
Loop 2: -44( -(54hms)(I3)-(18ohms)(I1)=-12V)
I3=(366 V)/(2052ohms)
I3=.178 A
4. Solve for I2, using loop 2
Loop 2:12V-(36ohms)(I3)-(18ohms)(I2)=0
12V-(36ohms)(.178 A)-(18ohms)(I2)=0
I2=.309 A
5. Sove for I1, using junction equation
Junction equation: I2=I1+I3
.309A= I1 +.178A
.309A -.178 A= I1
I1 =.131 A
Is this the correct way to do it
Thank You
Thread Closed
Thread Tools
Similar Threads for: Kirchhoff's Voltage Law
Thread Forum Replies
S4 helix of voltage-gated channels is the voltage sensor of the channel Biology 1
kirchhoff's second law....having exams soon, plz help Introductory Physics Homework 2
Kirchhoff's Rules? Introductory Physics Homework 1
Kirchhoff's Law Electrical Engineering 6
Kirchhoff's Law Electrical Engineering 1
