Calculating Force Away From Point of Application
The discussion focuses on calculating forces at a distance from the point of application, emphasizing the principles of static and dynamic equilibrium. To determine resultant forces and moments, one must sum all forces and moments in their respective directions. A specific example illustrates that a force applied perpendicular to a radial line creates a moment equal to the length of that line multiplied by the force, while also exerting a direct force at the point of interest. Key resources for further understanding include various educational websites on static and dynamic equilibrium.
  • Understanding of static equilibrium principles
  • Knowledge of dynamic equilibrium concepts
  • Familiarity with force and moment calculations
  • Basic physics knowledge related to vectors
  • Research "static equilibrium" in physics for foundational concepts
  • Study "dynamic equilibrium" and its applications in mechanics
  • Explore force and moment calculation techniques in engineering
  • Investigate vector analysis in physics for advanced understanding
Students of physics, engineers, and anyone involved in mechanics or structural analysis will benefit from this discussion on calculating forces and moments in relation to points of application.
indianmc
my question is at particular pont on any object some force has been applied. or it will experience a couple or moentum. how to calculate the force at some distance away from that particular point whare exactly the force has been applied.
The concept of "static equilibrium" or "dynamic equilibrium" applies to finding forces and moments in a body. Basically, to find the resultant forces and/or moments at a location far from where they are applied, you add all forces and moments up in the directions they are applied.
For example, a force applied perpendicular to a line that runs from the point of interest to the point where the force intercepts that radial line, creates a moment around that point equal to the length of the perpendicular line times the force. The force also produces a direct force on that point in the same direction and the same magnitude as the force.
Here's a few web sites that goes over some of this stuff.
http://www.uvi.edu/Physics/SCI3xxWeb/Structure/StaticEq.html
http://www.bsu.edu/web/jkshim/bm/kinetics/externalforce/externalforce.htm
http://www.glenbrook.k12.il.us/gbssci/phys/Class/vectors/u3l3c.html
Or just google "static equilibrium" or "dynamic equilibrium"
  • · Replies 35 ·
  • · Replies 36 ·
