Did I do damage to the multimeter?
  • Thread starter Thread starter Haftred
    Damage Multimeter
The discussion clarifies that connecting the black probe of a multimeter to the "A" port instead of the "COM" port while measuring resistance does not damage the multimeter. Users can still obtain correct readings, albeit with an opposite magnitude. The primary risk to a multimeter occurs when measuring voltage while set to measure current, which typically results in a blown fuse rather than permanent damage. This information is relevant for users of multimeters, especially beginners.
  • Understanding of multimeter functions and ports
  • Basic knowledge of electrical measurements (voltage, current, resistance)
  • Familiarity with multimeter safety practices
  • Experience with troubleshooting multimeter issues
  • Research proper multimeter usage and port functions
  • Learn about multimeter fuse replacement procedures
  • Study the differences between measuring voltage and current
  • Explore common multimeter troubleshooting techniques
This discussion is beneficial for electronics enthusiasts, students learning about electrical measurements, and anyone using multimeters for practical applications.
Haftred
I accidently put the black probe in the "A" port instead of the "COM" port and mistakingly measured resistance. The resistance measured seemed to be correct, but did I do damage to the multimeter?
no - 11 year olds use those multimetres nad stick things in the wrong way all the time. Your reading will have been correct but with opposite magnitude to what it should have had.
What were you trying to read, amperes? Where was the red probe plugged in?
The only thing that truly "blows" a meter is by trying to measure voltage while it is set to measure current, and even still, most meters will blow a fuse that is replaceable.
  • · Replies 31 ·
  • · Replies 19 ·
