Finding Partial Derivatives for z in f(x,y)=sin(x)*y - Bob
The discussion revolves around finding partial derivatives for the function z = y + f(x^2 - y^2), where f(x,y) = sin(x) * y. Participants are exploring the relationships between the variables and the derivatives involved.
  • Participants question the meaning of "complete partial derivatives" and whether it refers to total derivatives. There are attempts to express the relationship between the partial derivatives of z and the variables x and y, with some participants suggesting methods to derive the expected results.
There is ongoing exploration of the correct forms of the partial derivatives, with some participants providing guidance on how to express these derivatives in terms of the function f and its derivatives. Multiple interpretations of the problem are being discussed, and while some clarity is emerging, there is no explicit consensus on the final approach.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is a focus on ensuring the correct application of differentiation rules in the context of partial derivatives.
Bob19
On question
If I have the plane z = y + f(x,y) where f(x,y) = sin(x) * y
Is it possible to find the complete partial derivatives for z ?
/Bob
"Complete partial derivatives"?
Perhaps you mean the total derivative?
Help
Yes,
I made a typoo in my last post:
What I meant to write was
I'm presented with [tex]z = y + f(x^2 - y^2)[/tex]
I'm told this can be written as [tex]y \frac{\partial z}{\partial x} + x \frac{\partial z}{\partial y} = x[/tex]
Any idears on how I do that ?
/Bob
p.s. I get [tex]y \frac{\partial x}{\partial x} + \frac{\partial z}{\partial y} + 2x - y^2 \frac{\partial z}{\partial x} + x^2 -2y \frac{\partial z}{\partial y} = 0[/tex]
But how do I go from this result to the expected result ?
using the z-function as now given,
get [tex]\frac{\partial z}{\partial x}[/tex] and [tex]\frac{\partial z}{\partial y}[/tex]
Create the lhs using these values of [tex]\frac{\partial z}{\partial x}[/tex] and [tex]\frac{\partial z}{\partial y}[/tex] and you will end up with the rhs. viz [itex]x[/itex]
Edit: it's fairly simple - not complicated.
Okay
I then get
[tex]\frac{\partial z}{\partial x} = 2x[/tex]
[tex]\frac{\partial z}{\partial y} = - 2y[/tex]
What do I then do next ?
/Bob
Those partial derivatives are quite wrong, I'm afraid.
e.g. the partial derivative of y², wrt x, is zero!
z = y + f(x²- y²)
dz/dx = 0 + (f'')*(2x) where f' is the derivative of f wrt its argument.
and dz/dx is the partial derivative.
Here's how to do those partial derivatives.
[tex]\mbox{If }z = f(\phi),\mbox{ where } \phi = x^2 + y^2[/tex]
then
[tex]\frac{\partial z}{\partial x} = \frac{\partial f}{\partial \phi}.\frac{\partial \phi}{\partial x}[/tex]
where
[tex]\frac{\partial f}{\partial \phi} \mbox{ is } f'[/tex]
and
[tex]\frac{\partial \phi}{\partial x} = 2x + 0[/tex]
So,
[tex]\frac{\partial z}{\partial x}= f'.(2x)[/tex]
Bob19 said:
Okay
I then get
/Bob
Not quite right yet.
Have you seen my earlier post?
Bob, could you post a new message rather than sinmply editing an old post? No one can tell if you have responded or not unless they actually read the old message. If you post a new reply, it will show up as such in the forum index page.
Thanks
Yes sorry,
Please excuse me if mix up standard differentation and partial differentation
If [tex]z = y + f(x^2 - y^2)[/tex]
Can be written as:
Then to use the notation required in the task [tex]\frac{\partial z}{\partial x}= 2x \frac{\partial f}{\partial x}[/tex]
[tex]\frac{\partial z}{\partial y}= 1- 2y \frac{\partial f}{\partial y}[/tex]
If this is correct then how do I go from these two deriatives to the required result ?
Sincerely
/Bob
I'm afraid these partial derivatives are still wrong.
Have you read my earlier post, post #7, showing how to do the partial derivatives.
There should be a [itex]f'[/itex] in the expression for [tex]\partial z/\partial x[/tex]
Is it then ??
[tex]\frac{\partial z}{\partial x}= f'. 2x[/tex]
[tex]\frac{\partial z}{\partial y}= f'. 1- 2y[/tex]
/Bob
Bob19 said:
Is it then ??
/Bob
Almost there,
[tex]\mbox{The }\frac{\partial z}{\partial y} \mbox{ should be }\frac{\partial z}{\partial y}= 1- f'.2y[/tex]
[tex]z = y + f(\phi) \mbox{ where } \phi = x^2 - y^2[/tex]
[tex]\frac{\partial z}{\partial y} = \frac{\partial y}{\partial y} + \frac{\partial f}{\partial \phi}.\frac{\partial \phi}{\partial y}[/tex]
[tex]\frac{\partial z}{\partial y} = 1 + f'.(-2y)[/tex]
[tex]\frac{\partial z}{\partial y} = 1 - f'.(2y)[/tex]
Okay
Thank You very much :-)
My final question is than which approach do I have use to obtain that
can be written as
Do I add the two partial deriatives together ?
Best Regards
Bob
Fermat said:
Almost there,
[tex]\frac{\partial z}{\partial x} = 2x.f'[/tex]
and
[tex]\frac{\partial z}{\partial y} = 1 - 2y.f'[/tex]
So,
[tex]x.\frac{\partial z}{\partial y} + y.\frac{\partial z}{\partial y} = x.(1 - 2y.f') + y.2x.f' = ??[/tex]
Thank You again,
I can see that now that, those two equal each other, but how does it equal x ?
/Bob
and
So,
Bob, can you not see that,
[tex]x.(1 - 2y.f') + y.2x.f' = x - 2xy.f' + 2xy.f' = x\ ?[/tex]
Now I can ;-)
Thank You ;-)
/BOb
Thank You
