Velocity and acceleration vectors
The discussion focuses on calculating the J components of velocity and acceleration vectors in a parabolic motion scenario. The user identifies the I component of velocity as 2i and the J component as -1.296j, while also expressing uncertainty about determining the acceleration normal to the parabolic surface. The acceleration is suggested to be 0.6i + 9.21j, derived from gravitational effects. Key advice includes using the chain rule for derivatives and finding the minimum speed of a particle using its position vector r = 12(t^(0.5))i + (t^(1.5))j.
  • Understanding of vector components in physics
  • Familiarity with calculus, specifically the chain rule
  • Knowledge of parabolic motion and its equations
  • Ability to compute the magnitude of a vector
  • Learn how to apply the chain rule in physics problems
  • Study the derivation of velocity and acceleration vectors in parabolic motion
  • Explore methods for calculating the magnitude of a vector
  • Investigate the dynamics of motion on curved surfaces
Students and professionals in physics, particularly those studying mechanics and dynamics, as well as anyone involved in analyzing motion along parabolic paths.
Pepsi24chevy
I am having problems on how to find the J components in this problem.
http://www.mustangmods.com/data/16002/dynamics1.jpg
I know theI component of the velocity is 2i and that the j component is -1.296j but i don't know how to get this part. I thought u would plug the didstance d into the equation of the parabola but that didn't work out. I also dont' know how to find the acceleration normal to the parabolic surface. I believe the acceleration is .6i +9.21j in which i found the j vector by 9.81-.6.
the pin is sliding on the parabola because of the spring,
not because gravity pulls it down!
You want to use the chain rule here;
you're given y(x) and x(t) .
take symbolic derivitives first,
then substitute x = .27 [m], etc.
flabby_peanut said:
The position vector of a particle moving in the plane r = 12(t^(0.5))i + (t^(1.5))j, t > 0. Find the minimum speed of the particle and its position, when it has this speed.
I'm stucked here.
At minimum, v = dr/dt = 0
v = dr/dt = 6t^(-0.5) i + 1.5 t^(0.5) j = 0
How do I find time, t when I have the equation in terms of direction i and direction j?
I think that you should have started your own new thread rather than co-opting an old one.
Speed is the magnitude of the velocity vector. If you've got the the velocity vector in component form, how do you find the magnitude of that vector?
  • · Replies 37 ·
  • · Replies 21 ·
