Parallax Question and Shadow Q (Gnomon?)
  • Thread starter Thread starter picc84
    Parallax Shadow
The discussion revolves around two problems: one involving the height of a building based on the length of its shadow and the position of the sun, and the other concerning the concept of stellar parallax in relation to Copernicus's theory. The participants are exploring the relationships between angles, distances, and the geometry of shadows and celestial observations.
  • Participants discuss the need for sketches to visualize the problems, particularly the relationship between the sun's position and the shadow's length. Questions arise about the angle of the sun and its movement over time. The concept of parallax is also examined, with participants attempting to understand its implications in the context of celestial measurements.
There is an active exchange of ideas, with some participants suggesting visual approaches and others expressing uncertainty about mathematical concepts like trigonometry. While no consensus has been reached, several lines of reasoning are being explored, particularly regarding the geometry of shadows and the implications of parallax.
Some participants indicate a lack of familiarity with trigonometry, which may limit their ability to apply certain mathematical principles to the problems. The discussion also reflects a broader inquiry into the assumptions underlying the problems presented.
picc84
1) A student is standing on the east side of a building and notices that it casts no shadow. One hour later, she notices that the shadow of the building is about 3 feet long. Approx. how high is the building she is standing next to?
In this problem I honestly just don't know where to start. We've gone over gnomons in the class which I know use shadows to make projections, but the question is on the building and not what position the sun is in, as the gnomon is used for. I know there must be an equation to use for this but I can't find one in the textbook given. Any help on an equation I can use to figure this out?
2. One of the major scientific objections to Copernicus's theory was the absence of stellar parallax. Suppose that the most accurate measurement of the angles that defined the position of a star was good to 1/2 degrees in the time of Copernicus. How far away would the stars have to be compared to the earth-sun distance to explain the absence of observed stellar parallax in Copernicus's theory?
Is there an equation for figuring this out as well? I'm not trying to have anyone do this for me but I have absolutely no clue where to start on these two problems.
Always start by drawing a sketch
Especially if you're already stuck !
Do you know where the sun is if the gnomon
casts a zero-length shadow? ze
. . . what angle does Sun appear to move/hour?
Do you know what parallax IS?
Draw the Earth at 2 places on its orbit around Sun
(say, equinoxes). Put a star opposite Sun @ solstice.
The equinox lines-of-sight to that star
form a triangle with ½ degree apex angle.
Directly overhead, I think. Which happens at noon, right?
I don't know! I made a sketch of the situation like you said. If the sun was directly overhead, as it needs to be for no shadow, at noon, then one hour later it was one o'clock. Thats about all I've deduced.
I think its the displacement of an object caused by a change in the position from which its viewed. At least that's the def.
Ok I've sketched that too. But does that go towards an estimate of actual distance between the Earth and the star opposite the sun at solstice?
perhaps if we moved back a bit further do you know trig?
can you calculate a buildings height given the angle of the sun and the size of the shadow?
Are you aware that the sun appears to go completely around the Earth in 24 hours?
Are you aware that there are 360 degrees in a complete circle?
How many degrees does the sun move in 1 hour? :smile:
Ok so the sun moved 15 degrees in the hour that passed. Thats 15 degrees period since it was theoretically at 0 degrees the hour before, which it must have been to cast no shadow at all. And i know the shadow is 3 ft long. Where do I go from here?
gnpatterson,
No, I don't know trig. I'm TERRIBLE at math which is why physics sucks so much for me. I'm sure there's a way to calculate the buildings height with the information given, but I just don't know what the equation is.
if you do not know trig then you can still (just) do this problem
but you will have to use visual thinking, from your previous posts i suspect you are either entirely female or have major cognitive functions located in the opposite hemisphere of your brain.
if you can visualise a circle with its center at the top of the building, then you might just be able to see the shadow moving out along the rim of the circle.
If you can intuit from the fact that the shadow has move three feet in one hour and the shadow will return to the same point in 24 hours you may work out the circumference of the circle and therefore its radius (the height of the building).
  • · Replies 21 ·
13K
