How Do Nurses Calculate the Weight of a Patient Using Newtons?
  • Thread starter Thread starter themadperseid
    Method
The discussion revolves around calculating the weight of a patient based on the forces exerted by nurses and the acceleration of the patient. The subject area includes concepts from mechanics, specifically Newton's laws of motion and weight calculation.
  • Participants are attempting to calculate the patient's weight using the forces exerted by the nurses and the given acceleration. There are differing results, with some participants questioning the correctness of the initial answer provided.
The discussion is active, with multiple participants providing their calculations and results. Some guidance is offered regarding the relationship between force, mass, and acceleration, but there is no explicit consensus on the correct weight of the patient.
Participants are working with specific known values, including the upward force exerted by the nurses and the acceleration of the patient. There is an emphasis on understanding the forces involved in lifting the patient, as well as the gravitational force acting on the patient.
themadperseid
Here is the question
To lift a patient, four nurses grip the sheet on which the patient is lying and lift upward. If each nurse exerts an upward force of 240n, and the patient has an upward acceleration of .504 m/s^2, what is the patients weight.
answer: 913 N
HOW DOES THIS WORK. THANKS
weird, I keep getting 638N
Are you sure this answer you provided is correct?
I get 913 N as the weight as well.
960 N=W+m*.540 m/s^2
960 N= m(g+.54)
m=93.08 kg
W=mg=913 N
riru, just in case u missed that,
knowns
960n force up
.504 m/s^2 acceleration
n=kg*m/s^2
960n=?kg*(.504+9.8)---->to accelerate upwards, the force is the upward velocity, plus gravity, since that is being overcome.
thus, you have 93.2kg patient (mass)
w=mg
so 93.2kg*9.8m/s^2=913n
  • · Replies 38 ·
