What Determines the Characteristics and Dynamics of a Wave?
  • Thread starter Thread starter hotmail590
    Formula Wave
The discussion revolves around the characteristics and dynamics of waves, specifically focusing on the wave function represented by the formula y(x,t) = Asin(kx-wt). Participants explore the roles of various parameters such as amplitude (A), wave number (k), and angular frequency (w) in determining wave properties.
  • Participants inquire about which variables are independent and discuss the implications of constants like k. They also question the parameters that define wave characteristics, including amplitude, wave number, and angular frequency. Various aspects of the wave, such as phase, wavelength, and period, are examined, with participants suggesting potential formulas and relationships.
The discussion is ongoing, with participants seeking clarification on definitions and relationships between wave parameters. Some have provided insights into the properties of the wave function, while others are still exploring their understanding of the concepts involved.
Participants are encouraged to reference their textbooks and consider graphical representations of waves to enhance their understanding. There is a mention of potential limitations in the resources being used for study.
hotmail590
Wave formula: y(x,t) = Asin(kx-wt)
[] Which variables (x, t, A, k, w) are independent?
Would k be the only independent variable since it is a constant?
However I am not too sure what exactly does the k represents.
Can someone please clear that up for me?
[] Which of the following are parameters that determine the characteristics of the wave? x only, t only, A only, k only, w only, x and t, w and t, A and k and w.
Would A and k and w determine th characteristics of the wave?
I know that A is the amplitude of the wave and w is the angular frequency
of the wave so those 2 has to be characteristics of the wave.
[] What is the phase of the wave?
That would be (kx-wt) right?
[] What is the wavelength of the wave?
Would that be 2pi/k?
[] What is the period of this wave?
Would that be 2pi/w?
[] How do I find the speed of propagation v of this wave?
Thank you for your help.
please anyone?
WAve function components.
A can be a function of both time, and space(A(x,t)) unless specifically stated otherwise. It is typically the amplitude, or height of the wave form.
w (omega) is a radian/second-- angular velocity-- function.
k is the restoring force component for an oscillation. It is also noted to be the wave # in optics. In standard oscillations, it's the above stated item.
I.e., it has the property of pulling the oscillation back to zero. We call is the "spring Constant."
l is the wavelength. It is defined by the values-- 2pi*nu/w
Each of the items create a specific aspect to the wave. If any of them are different, you'll have a different form on some level.
Would that be 2pi/k?--
look at the units of each element
Take the time derivative of A*sin(kx-wt)= -w*A cos(kx-wt)
remember, w = rad/sec. Radians are unitless. A has units of length. the sine function is also unitless. Therefore, -w*A... has units of m/s. In this case, the velocity is negative because the angular velocity is negative.
Each element has specific properties that contribute to the entire wave form. Go back and reread the text you're using.
If it does not adequately describe the wave, locate another source.
Do you have the capacity to graph this wave? Calculator, Maple, Mathmatica, Matlab, etc..?
Pick values for each element, and insert into graph. Change them one at a time, and you'll see how much each affects the total form.
