Milliken Oil Drop Experiment. .
The Milliken oil drop experiment involves calculating the charge of an electron using data from suspended oil drops. The correct approach requires calculating the electric field (E) using the formula E = V/d, where V is the voltage and d is the plate separation. The mass (m) of each drop is determined from its volume and density, and the charge (q) is calculated using the equation q = mg/E for each drop individually, rather than averaging values. The final charge on the electron is derived from the individual calculations of q.
  • Understanding of electric fields and forces
  • Knowledge of the relationship between mass, volume, and density
  • Familiarity with the concepts of gravitational force and weight
  • Basic proficiency in algebra for solving equations
  • Calculate the volume of a sphere using the formula V = (4/3)πr³
  • Learn about the principles of electrostatics and electric fields
  • Study the concept of gravitational force and its calculation
  • Explore the significance of the Milliken oil drop experiment in physics
Physics students, educators, and researchers interested in electrostatics and experimental methods for measuring fundamental charges.
shikagami
Can some one help me with this Milliken oil drop problem.
Data from a Milliken oil drop experiment are given below. Calculate the value of the charge on an electron from this data:
Voltage needed to suspend drop (V) Drop diameter (microns)
103------ 1.1
44.7----- 1.2
127------ 1.6
175------ 1.5
11.3----- 0.9
Given:
Plate separation: 0.5cm
Density of oil: 0.95 g/mL
Gravitational constant: 9.80 m/s^2
Ok... this is what I did: q=mg/E
1. I calculated for electric field first since: E= kV/m
2. One microns is equal to 10^-6 m
3. I changed volts into kV.
4. I took the average of all 5 of the electric fields and got 67896.71718 kV/m
5. Now I solved for the mass by cubing the plate separation and canceled it with the mL... to get grams then I changed grams into kilograms to get 1.1875 x 10^-4 kg.
6. And finally I plug everything back into the equation: q=mg/E and get the answer of 2.706 x 10^-8 coulombs.
Please tell me if I did it right.
Chemistry news on Phys.org
No, you made mistakes because you have not properly understood the concept.
1. The force on a charge q due to an electric field E is qE. The electric field between a pair of plates at a voltage difference V, is given by V/d, where d is the distance between the plates (and has nothing to do with the size of the drop).
2. The gravitational force on the oil-drop is its weight, mg. m is the mass of the drop which is the product of volume and density. You are given the density, and you can calculate the volume of each drop assuming it is a perfect sphere.
3. For the drop to be suspended between the plates, the upward and downward forces must match. So qE = mg or q = mg/E. Having found m of each drop and the corresponding E acting on it, you can find the value of q on each drop. Do not average all the values; find for each case separately.
4. Use the different values of q to find the answer.
  • · Replies 52 ·
