Calculating Dew-point from RH & Temp
  • Thread starter Thread starter ZegeunerLeben
The discussion revolves around calculating the dew point from relative humidity (RH) and temperature, focusing on the relationship between vapor pressure and saturation conditions in the air.
  • Participants explore the definition of dew point and its relationship to vapor pressure and relative humidity. There are attempts to derive the dew point using saturation vapor pressure values and questions about how to apply these values to find the dew point temperature.
The discussion is active, with participants sharing insights about the relationship between temperature, relative humidity, and vapor pressure. Some guidance has been provided regarding the use of experimental tables for saturated vapor pressure, but no consensus on a specific formula or method has been reached.
Participants reference tables of saturated vapor pressure at various temperatures, indicating reliance on empirical data. There is an acknowledgment of the complexity involved in calculating the dew point and the need for accurate values to proceed.
ZegeunerLeben
>>Anyone know the formula for this? Haven't been able to find one on the net that works out when you run the numbers through a psychrometric chart. Any help appreciated!
If I remembers it correctly ??
Due point is the temperature at which the moisture present in the air at room temperature is sufficient to saturate it.
As quantity of unsaturated moisture in the air is not changing till the due point, by decreasing temperature, vapour pressure remains constant. Hence
RH = unsaturated vapour pressure at room temp./ saturated V.P.at room temp.
= saturated v.P. at due point/saturated V.P. at room temp.
The experimental values of Saturated vapour pressure at different temperatures are given in the tables.
>>Okay, lesse. Since I know the temp. in the space, I can approximate my saturation vapor pressure (Temp>0 and constant).
>>Do you know by how much?
Then since I know the RH in the space and now know the saturation vapor pressure I can get the unsaturated vapor pressure in the space. But how do I use that data to determine the dew-point temp at which saturated equals actual i.e. RH=100?
I got a table in an old booK for saturated vapour pressure, see if this can help you..
Temp. in deg C -- SVP in mm of Hg
-10--2.1
-5--3.1
0--4.6
5--6.5
10--9.2
20--17.5
30--31.7
40--55.1
50--92.3
60--149.2
70--233.5
80--355.1
90--525.8
100--760
110--1074.5
120--1489
150--3569
200--11647
Inbetween the two given temperatures it is calculated by finding the rate of increase in that range x increase in temp.
(The image file was too large to be attached)
>>Thanks mukundpa!
:smile:
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 21 ·
