How Many Moles of Ions Are in These Aqueous Solutions?
The discussion revolves around calculating the number of moles of ions in various aqueous solutions prepared by dissolving specific compounds in water. The subject area includes concepts from chemistry, particularly stoichiometry and ionic dissociation.
  • Participants discuss converting grams to moles and the relevance of solution volume in the calculations. Questions arise regarding the necessity of multiplying by the volume after finding moles, and the importance of considering ionic dissociation in the final count of moles of ions.
Some participants have provided insights into the dissociation of cobalt(III) chloride and the stoichiometric relationships involved. There is an ongoing exploration of the correct approach to determine the total moles of ions, with no explicit consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. The question specifically asks for the number of moles of ions, which has prompted further examination of the initial calculations and assumptions made.
courtrigrad
How many moles of ions are present in aqueous solutions prepared by dissolving 10.00 g of the following compounds in water to make 4.35 L of solution?
(a) cobalt(III) chloride
(b) aluminum carbonate
(c) potassium permanganate
(d) strontium hydroxide
I first converted the 10.00 g into moles, and divided by the molar mass of each of the compounds, and multiplied the result by 4.35 L. But I am not obtaining the correct answer.
Any help is appreciated
Thanks
Can you show how you did that for the first compound? It will make it easier to see where you're going wrong.
Thanks.
Upon closer inspection, I have a question.
Why would you do that? :confused: If you convert from grams to moles, multiplying by liters is only going to screw up the units.
Ok so we have cobalt(III) chloride or [itex]CoCl_{3}[/itex]. Its molar mass is [itex]58.93 + 3(35.34) = 164.95[/itex]. 10 g of this stuff is thus 0.06 moles. All I know know is that [itex]M = \frac{mol sol}{L solv}[/itex]
Yah, [itex]M = \frac{moles}{volume}[/itex]
OK, that's a big help. I can clearly see exactly why you are not answering the question. :biggrin:
Look at the dissociation reaction:
[tex]CoCl_3(s)\longrightarrow Co^{3+}(aq)+3Cl^{1-}(aq)[/itex]<br /> <br /> Now the question asks you how many moles of <b>ions</b> are in each solution. So once you have the number of moles of [itex]CoCl_3[/itex], you need to use stoichiometry to get the number of moles of each ionic species. Then, since the question asks for the number of moles of ions in the solution, you'll have to add up the results.<br /> <br /> Same goes for the other compounds.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> All I know know is that [itex]M = \frac{mol sol}{L solv}[/itex] </div> </div> </blockquote><br /> You don't need this at all.[/tex]
Here's a hint for you: Read again what it is that the question is asking for. Sometimes there is extra information you don't need (or maybe you need it for another part of the question). Also, it is asking for how many moles of ions you have. What extra step might you need to add to account for that?
Edit: Tom was quicker than I was! :biggrin:
13K
13K
15K
